Dx Blame MKIII-Hx - Builder's thread - Page 101 - diyAudio
Old 18th February 2012, 06:47 PM   #1001
This image shows the wiring...
It should allow you to use your original 12VA transformer
currentflow
Old 18th February 2012, 07:30 PM   #1002
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Hi currentflow,
Thanks for your patience, that you help me to solve this problem with the 7812 regulator and the image.
I'm waiting on email, and post the answer here.
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 18th February 2012, 07:50 PM   #1003
Originally Posted by BMW850 View Post
Hi currentflow,
Rudy
My pleasure. While you're waiting for that email, please try the diodes (if you have any).
As I see it, your options are:
a) Fit the extra two diodes and possibly increase the values of C1 & C2 to 470uF/25V each, or
b) Use a 12-0-12 transformer, connecting it to all three board terminals.
With half-wave rectification and the relatively low-value smoothing capacitors (2 x 100uF), you're just not getting enough current into the regulator.
currentflow
Old 19th February 2012, 09:03 AM   #1004
BMW850's Avatar
Thanks currentflow,
My intention was to 12-0-12 2A ordering, also stood on the board 12-0-12
But vintage_audio_lab told me via email that 12-0 1A was enough for this application, thats the reason why I ordered this 12-0 1A transformer.
Dear Sir:
http://www.okaphone.nl/product/images/212048c.jpg
This transformer is 12-0-12 full wave output.
What you need should be simpler one. Just need to have one 12-0 output, 1A current is quite enough.
Sincerely, Kevin
- vintage_audio_lab
When I get no email after this weekend , I order this 12-0-12 2A transformer.
Then I take option B
I'm still waiting on email,
Rudy
Old 19th February 2012, 09:44 AM   #1005
Thanks currentflow,
Rudy
Hi Rudy,
Using option a) will cost less than 1 euro for two diodes and achieve exactly the same result. You would only need to install two diodes on one board and then connect the three power terminals of each board in parallel. This makes the most sense when you have a perfectly good transformer
currentflow
Old 19th February 2012, 11:04 AM   #1006
BMW850's Avatar
I tested this module also with 12v 10A torriod , and I have also a voltage drop, how do you explain this?
Sorry I question this, because my electro knowledge does not go as far to understand this
Sorry I have no diodes to test, but I will order diodes.
Rudy
Old 19th February 2012, 11:18 AM   #1007
Rudi_Ratlos's Avatar
Rudy,
with your current implementation (you have the 2 upper diodes, D1 and D3 installed), the current does not know where to flow back.
Get the 2 diodes that CURRENTFLOW told you, solder them correctly - and you are done.
Best regards - Rudi
Old 19th February 2012, 02:44 PM   #1008
BMW850's Avatar
I have searched and found 4 x 1N4007
I have soldered 2x 1N4007, this is the result.
Before speaker protection goes on:
Regulator 7812 input, 17,34v
Regulator 7812 out, 12,10v
Speaker protection goes on:
Regulator 7812 input, 15,10v
Regulator 7812 out, 11,87v
This is much better, you see now a little voltage drop
Rudy
Old 19th February 2012, 04:15 PM   #1009
Rudy
This is because before you added the two extra diodes, you had a half-wave rectifier. Capacitors C1 and C2 (both 100uF) only became charged on the positive peaks of the AC input cycle, while the negative peaks were being unused. Their values were too low to maintain the voltage in this way and were discharging faster than they were being charged.
Adding the two extra diodes causes these capacitors to charge on the negative half of the cycle as well as the positive. Therefore the capacitors are now being charged twice as often as before and you now have full-wave rectification. Increasing C1 and C2 to 470uF (25V) would improve the situation even further under load when the relays are on. I hope that makes sense.
currentflow
Old 20th February 2012, 04:53 PM   #1010
BMW850's Avatar
I posed this question to vintage_audio_lab,
When you look at this forum, I am busy with the speaker protection module , and measure weird things:
What is the utility of this 7812 regulator in this circuit, I have a voltage drop, with this 7812 regulator.
This is the answer to my question:
Dear Sir:
7812 regulator was used for dc detection and time delay circuit. And relay also need dc supply to drive it.
Sincerely, Kevin
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 05:34 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 04:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 03:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 07:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Copyright ©1999-2017 diyAudio
