Dx Blame MKIII-Hx  - Builder's thread
Old 14th September 2011, 11:29 PM   #91
a.wayne is offline a.wayne  United States
Sin Bin
Hello Carlos .
Thanks or the explanation and agree it can be as bad as good. Is that design really capable of regulating voltages to such a powerful amplifier..? or is it better suited for lower power outputs ?
Old 15th September 2011, 03:16 PM   #92
Junie is offline Junie  Philippines
Finally I got my boards, good looking PCB eh! a bit bended due to shipping maybe but no worries it's still usable. Gonna populate with available parts tonight.
Thanks Byron.
Old 16th September 2011, 01:13 AM   #93
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Increases cost A Wayne..... the cost is almost the same you spend in your power
amplifiers.... current that will cross will be two channels current to a single regulator, there's some voltage drop over the series pass transistors and huge current.... this increases cost.
Also if you have a high power amplifier, draining several amperes, then you will need several output transistors and regulator input voltage use to be 20 to 30 volts higher than your output voltage.
Imagine a 60 volts power amplifier.... a regulator to it will have 80 to 90 volts... so, 20 to 30 volts higher than the output voltage.... and imagine the current....let's say 20 amperes each rail because two amplifier channels connected to the same electronic supply.... one rail will dissipate the voltage from the coletor to emitter multiplied by the current.... the voltage may drop to 75 volts loaded...so, 15 volts of voltage drop multiplied by 20 amperes results in 300 watts...and we are talking about one rail..... two rails will dissipate twice ..... now imagine the heatsink size to dissipate the heat resulted of 600 watts.
Not a good idea to use in high power amplifiers...this is good to 20 watts or 30 watts channel amplifiers, but even this way doubles the cost..so, the most rational way, the cheaper way, is to use a transformer, rectifiers and filters... to accept some voltage drop and save money.
To high power amplifiers it is a better idea to use a SMPS....but not a common, regular, generic, ordinary SMPS...it must use a very high frequency oscilator in order not to be amplified in your audio stages, say, captured as an interference and then amplified because the amplifier can do that (high frequency transistors)... this will overheat your amplifier if your SMPS is low frequency (20 to 40 Khz) with the signal being amplified...this will result in saturation, audio compression, losses of high end reproduction, compressed sound (no dinamics).
That SMPS (switching mode power supply) must be shielded inside a mu metal case (magnetic shield).
That SMPS must accept 30 thousand plus 30 thousand microfarads in it's output in order to have a very low impedance in the supply output seen by the amplifier...amplifier will "feel" a low impedance...the huge stock of electrons will be fast delivered to the load when the SMPS is not always fast enough to supply surge of currents to face transients or signal peaks...usually SMPS senses the surge of current when you switch the SMPS on and understand the surge as a short circuit and shut down the supply...so..... that supply must be a special SMPS, not a standard one..to accept huge bank of condensers in the output without enter the protection mode.
So, there are problems to use a SMPS, also there are problems to use a voltage regulator to high power amplifiers.... there are technical problems and huge costs too...weight, room inside the enclosure for big heatsinks (extra ones to the series pass regulator).
The most rational decision is to use the old and good transformer, rated to your power, a good and old bridge rectifier rated to your power and a huge bank of electrolytic condensers and not to complicate our life with all that stuff.
I am building because i need as a tool, to adjust the voltage need to supply energy to several different amplifiers and ideas i use to develop or test.... as a workbench instrument, a laboratory supply, adjustable, stabilized and huge....but i will never install that monster inside an enclosure to feed an amplifier.... when building an amplifier, inside the enclosure you will always see analog supply, conventional supply... trafo, rectifier and filters.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 16th September 2011, 08:07 AM   #94
Default update
MJ's trannies are hard to find here in dubai, please advice a recommended replacement (Jap's counterpart)? Thanks.
Old 16th September 2011, 08:56 PM   #95
Default 2SC4793 and 2SA1837 may fit
I suppose they will .... but i cannot guarantee that because i have not test them.
regards,
Carlos
Old 17th September 2011, 03:24 AM   #96
ByronInPortland is offline ByronInPortland  United States
ByronInPortland's Avatar
Talking Got my power supply up and running
I'm posting a schematic & photo just because this is the first power supply I've designed and the second one I've built, so I'm feeling pretty smart right now. I got some advice in the Power Supply forum. It's a super super simple linear supply. The transformer is 40V+40V, 300VA. I'm going to build two of them, one for each channel. I measured 58.9V across both pos-ground and neg-ground, which is more than I should get from 40V secondaries, but I didn't check my mains voltage. I don't have the tools to measure noise. The 2.7mF caps on the right side are the 4 big caps on the board. Someone suggested that additional caps be at 25% the capacitance of the other filer caps.
My only concern is that the bleeder resistors get hotter than I would like if the rails are left open - hot enough that it's painful to hold them tightly. If anyone thinks they should be more than 2Kohms or rated more than 3W, please say so.
Old 17th September 2011, 04:27 AM   #97
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
2K isn't that to much for a bleeder?
Old 17th September 2011, 04:38 AM   #98
Sin Bin
Byron , isn't that psu a bit small for such a powerful amplifier ...
Old 17th September 2011, 04:56 AM   #99
My understanding of bleeder resistors is that their only purpose is to allow the cap to discharge after turning off the amp, and that it will not hurt to let the caps discharge slowly. Furthermore, they waste power when the amp is running, so a high value is good. Please correct me if I'm wrong. What bad thing will happen with too high a resistance?
Yes, it is, but remember I have two - one for each channel. I'm using these transformers because I already had them. Everything else is rated for at least 64V, so I can replace with bigger transformers later if I want. I hope you're not referring to my capacitor bank, as those monsters are expensive!
I appreciate any advice/suggestions
Old 17th September 2011, 08:58 PM   #100
canonnica is offline canonnica  Canada
Default Air core inductance
The output inductance is a tight fit, so much I doubt we can obtain the suggested 2.2uH.
12mm outside dia x 22mm long is the maximum permitted. However with 18AWG bare copper wire, it needs to be either 12mm x 28mm (24 turns), or 14mm x 22mm (19 turns)
What obtions should we look at?
Dx Blame MKIII-Hx  - Builder's threadHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 10:53 PM
group buy for DX Blame MKIII Hx PCBs ByronInPortland Group Buys 252 13th May 2016 05:14 AM
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 04:01 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 08:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
