Old 31st July 2011, 01:41 AM   #1
Default Best Amp for my Speakers
I Have built these bookshelf speakers as my main speakers
The Seas ER18DXT ported two way
What forum amp should I build to would work the best with these speakers they are 8 ohms and about 80watts max. (I'm am looking for the highest SQ)
My enclosure is a Niles GXR2 Power Amp with 1000W transformer and the PSU voltage is +/-45V. I want to use 2SC5200/1943 Output transistors.
Old 31st July 2011, 04:44 AM   #2
ostripper's Avatar
The small DX amp is the best for >80w ... Dx Blame ST - Builder's thread - post pictures, reviews and comments here please.
(ST blame)
Bootstrapped , high gain lin amp. uses your outputs , too.
The DIYA amp (coming soon -150W) is too big , would possibly overwhelm those speakers.
OS
Mongrel website , always current and updated :
http://67.248.209.21/D%3A/WEBSITE/
Old 31st July 2011, 11:10 AM   #3
Does the DX Blame ES sound as good as the Precision I (soundstage, details, lows, highs) (low THD)
What amp on the forum has the "Best SQ" low THD, noise, slew rate.
Old 31st July 2011, 11:34 AM   #4
ostripper's Avatar
fast is not always best. a smaller version of the "DIYA amp" with TMC , or dadods " bootstrap+TMC" is the fastest (100v/us).
DX's ST is close 50-60V/us ... but this metric is not the only one to determine sonic quality.
depending on how many amps you have done (skill level), the Blame ST gives the most for the least (easy) at the 60W level.. (only my opinion)
OS
Old 31st July 2011, 11:51 AM   #5
How does the DX Blame ES compare to SymAsym amp
B&W speakers,custom CNC enclosure speakers,radial horns felixx Vendor's Bazaar 0 6th April 2011 08:15 AM
Will this work? Disassamble my old three ways & make small speakers w/seperate woofer chris conery Multi-Way 0 18th April 2007 10:46 PM
Dividing power between different speakers from single source & Combining channels Fusion-One Parts 0 10th April 2007 01:18 AM
Multi-room audio system (speakers & Amp question) dwalter Multi-Way 0 17th November 2004 07:22 PM
what tube preamp DIY kit to match B&W P-5 speakers skydog Tubes / Valves 4 22nd January 2004 09:48 PM
Page generated in 0.08790 seconds (61.19% PHP - 38.81% MySQL) with 10 queries
