Old 28th July 2011, 09:21 PM   #1
Default Need help repairing Yorkville MP6
http://www.yorkville.com/downloads/other/smmp6.pdf
Driver and output components, resistors and diodes all measure good before power on, then output shorted. This is my 3rd times already.
Need some advise.
Anyone can help?
Thanks.
Old 29th July 2011, 12:50 PM   #2
I would start by removing the 4 output transistors and R11. Replace R11 with 2 resistors of about 1/2 value, their centre connected to the output rail. Instead of the speaker use a 100 Ohm resistor the load. Than measure the voltages. Good luck! E
Old 29th July 2011, 03:44 PM   #3
Thank you mickeymoose
following your advise, R11 with 2X20 ohms center to speaker out, measure with no load.
Speaker out close to 0 volt.
The voltage is 4.4v at base of Q11 and -4.4v at base of Q10.
U2 pin1 is 4v, pin7 is 4v.
U2 pin8 is 16.5v, pin4 is -16.5v.
Q7 base 2.5v, collector 3.15v, emitter 4.4v.
I have the vr to min. the voltage between the 2 base is 8 volt.
shouldn't D9, D10, R37, D27 Q7 R38 plus the vr controls the voltage to around 3volt between the 2 bases.
Need more help.
Thank you.
Old 30th July 2011, 01:56 AM   #4
Enzo is offline Enzo  United States
8 volts of bias??!! That ought to burn up your outputs pretty well. They would be running pretty hot, I;'d think. Yes, I'd want to see something closer to 3 volts.
verify the resistance of the R37, R38. You may have to lift them from the circuit to measure. And check the junction voltage drops of the two diodes. But more important, check the bias transistor Q7.
But my main suspect here would be the bias control itself. I can't read the part number. Make sure the little trim pot is not open at either end, and that the wiper works.
You want Q7 conducting harder.
Old 31st July 2011, 08:43 PM   #5
Problem found, Q7 is defective, which is hidden in the heat sink.
Thank you all from pointing me the right direction.
Modding the Yorkville Unity jdubs Multi-Way 50 18th June 2010 11:21 PM
Yorkville Unity - Listening Height jdubs Multi-Way 3 26th March 2009 03:31 AM
Yorkville 400B Bass Head Repair Help cm961 Solid State 0 20th February 2009 02:47 PM
What frequency do that ones run at Yorkville NX55P? lindomar Class D 0 3rd November 2007 12:33 PM
Yorkville PA powered head distortion still4given Solid State 4 14th February 2005 03:31 AM
Page generated in 0.08072 seconds (75.57% PHP - 24.43% MySQL) with 10 queries
