Old 25th July 2011, 07:42 PM   #1
suddy is offline suddy  England
Default Marantz SR2000 Receiver: Worth saving?
Hello.
I bought a Marantz SR 2000 Receiver from a car boot sale yesterday. Paid £3.
It is very quiet. What I mean, is, in order to listen at a reasonable volume, the control is 2/3 the way round. If I max the control, I only get a more distorted (not louder) sound. It happens on Phono, Line Level and with the tuner section.
I don't think this is by design.
Is it worth my time to find the fault and fix it, or shall I not bother and throw it in the bin? I wonder if anyone has heard of the problem and knows a quick fix?
Any help would be gratfully received.
Old 25th July 2011, 07:58 PM   #2
sakis is online now sakis  Greece
sakis's Avatar
sorry to say that there nothing special about this amplifier BUT ...
you may always keep as a classic piece and will always sound sweet and coloury ( sound will have a certain colour not real but kinda pleasent )
a pair of small nice speakers and you will have a sweet secondary system
Rule :
to keep it alive for many years to come you need to replace all electrolytics form inside ( all means all and that will include tuner electrolytics also )
spray also pots and switches and you are done for another 30-40 years ...
you may find that after the repair you also have aquiet sensitive tuner
some more info in a can can be found here vintage amplifier repair/upgrade manual
email me also if you need schematic or aditional help
kind regards sakis
Edit : Do not touch any of the trimers in the tuner ..if you have any trouble in tuner area 99% is coming from electrolytics
as about the fault is 50% electrolytics 50% dirt
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 26th July 2011, 11:36 AM   #3
Thanks for your help. I think I'll save it from the bin!
Old 26th July 2011, 05:17 PM   #4
sregor is offline sregor  United States
Eliminate easy problems first. Check for shorting jacks in tape outputs (should only be in unused inputs if there at all) Work the tape monitor switches. Cleaning may cure probblems.
Steve
Old 26th July 2011, 05:35 PM   #5
kevinkr's Avatar
Edit: No switch or link between internal pre and power amp so have deleted that comment.
After that suspect that there is some internal problem that could be supply or component related, bad relay or switch contacts or similar since it affects both channels.
www.kta-hifi.net
Old 28th July 2011, 08:59 PM   #6
It turns out that it was a fuse. None of the backlights worked, which I assumed was bulb failiure in the first instance.. Tracing the circuit lead me to the fuse on the PS board..
Thanks to all for your help, fuse very happy with it now and I'm glad that I didn't throw it away!
Stephen
Old 28th July 2011, 09:04 PM   #7
sakis's Avatar
you will in the feature if you dont take the advice that was given for free to u
happy regards
sakis
Old 28th July 2011, 09:28 PM   #8
kevinkr's Avatar
happy regards
sakis
Yes, a recap is definitely in order at this point. Might even have something to do with the blown fuse...
www.kta-hifi.net
Marantz CD-95 worth it (CDM1)? asturias Digital Source 1 21st November 2009 03:33 PM
Ampex 6v6 PP.. worth saving? wicked1 Tubes / Valves 5 28th September 2009 04:38 PM
Sony Receiver GX60ES for $100, is it worth it? gychang Solid State 0 31st January 2007 02:15 AM
What's a marantz cd-67se worth? elizard Digital Source 12 13th January 2004 12:08 PM
Is Marantz CD84 worth buying to modify hifileslie Digital Source 3 8th December 2003 11:11 AM
Page generated in 0.11176 seconds (73.02% PHP - 26.98% MySQL) with 10 queries
