6 amp circuit one power supply unit advantages/disadvantages
Old 25th July 2011, 06:13 PM   #1
troyo is offline troyo  Guyana
Thumbs up 6 amp circuit one power supply unit advantages/disadvantages
hi i have 6 amp circuit 200w into 8 ohms and want to use one transfromer(1500va) 20000uf of capacitors .here the thing if i were to use these amp in a tri amp design(2 highs /2 mids /2 lows) would there be any audio problems as a result of using one power supply unit
Old 26th July 2011, 02:06 AM   #2
twest820 is offline twest820
Have a look at the coupling possibilities between channels and then you'll know. Assuming good grounding usually the limiting factor is supply ripple---at typical listening levels ripple is usually dominated by the amp's quiescent draw and the control loop's PSRR isn't always high enough to deliver a good SnR on the output due to the relatively low ratio of output to idle power. If that's the case for your amp then the corner of interest is likely to be with five of the channels as aggressors and one tweeter as the victim. Output power depends on driver efficiencies, crossover points, and listening configuration but for a typical triamp 1mW per mid and low and 100uW per tweeter is a reasonable starting point.
Given good parts choices and layout an op amp based control loop running off regulators usually has sufficient PSRR margin a common supply's fine. Differential topologies make this easiesr. If you're doing discrete control and unbalanced, well, that's harder.
Old 26th July 2011, 10:06 AM   #3
Henry8 is offline Henry8
I built a 6-ch pa with layout as follows:-
I I
I O I
I I
ie txmf in middle with 3 amps on sinks either side.
Screening of the trmr is very important, including ac wiring to rects.
I used 1 rect 2 caps for each channel.
The amps driver ccts were fed by regulated supplys.
Old 27th July 2011, 02:47 PM   #4
hi i want to when playin if the bass will suck some of power thus causing mids and highs sound quality to change as a result of lak of power
Old 27th July 2011, 04:09 PM   #5
Originally Posted by troyo View Post
6 amp circuit 200w into 8 ohms..... in a tri amp design(2 highs /2 mids /2 lows)
Is this a PA or home system?
What is the load on the amps o/p's?....a single 8R driver?
Power distribution will depend on the xover frequencies.
6 amp circuit one power supply unit advantages/disadvantagesHide this!Advertise here!
MTTM advantages/disadvantages? jjkozlow Multi-Way 17 16th January 2012 06:30 AM
Advantages and disadvantages in the location of the port - bottom speaker kappa_ii Multi-Way 8 3rd April 2011 10:58 PM
Parallel output tubes/valves in push pull. Advantages/disadvantages? Matt BH Tubes / Valves 42 20th May 2010 04:27 AM
Chassis metal advantages/disadvantages? bereanbill Tubes / Valves 60 9th June 2009 04:29 AM
