Old 25th July 2011, 03:45 AM   #1
john65b is offline john65b  United States
john65b's Avatar
Default Denon DRA-685 NO POWER
Hey all,
A friend brought over his broken DRA-685 tonight and there is no power. He said he thinks its stopped working after a thunderstorm...possibly a lightning strike...
Anyway, fuses are fine. I noticed that the Power connector is two pronged (no ground).
There is continuity on hot plug spade to both fuses and transformer primary winding, but no continuity on the Neutral power spade to the other transformer primary connection. It appears the neutral leg is switched on by a relayed circuit...
I have read that these Denons have all sorts of problems, including no power at all...
Anyway, I am thinking of jumpering the power neutral to the transformer primary (bypassing the switching) to see if it will come up... any ideas?
"I speak Spanish to God, Italian to Women, French to Men, and German to my Horse" - Charles V
Old 25th July 2011, 04:03 AM   #2
49 - for the 16th time
c2cthomas's Avatar
Hi John - you can download a service manual from here - DENON DRA-685 Service Manual free download, schematics, eeprom, repair info for electronics
Check around the net for more info. I don't have any experience with Denon's - sorry.
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 26th July 2011, 02:35 AM   #3
john65b's Avatar
I can't seem to download the manual...it directs me to a PDF reader (don't need one)
Old 26th July 2011, 02:45 AM   #4
c2cthomas's Avatar
In the lower portion of the screen you should see an image of the pdf 1st page. To the right of that should be the words "get manual" - click on get manual phrase in what looks to be a sort of burnt red or brown color.
Old 26th July 2011, 03:08 AM   #5
john65b's Avatar
OK...sorry. Got it.
Thanks!!
Also found a cap on the relay switch that looks to have blown...
Old 26th July 2011, 03:23 AM   #6
c2cthomas's Avatar
Hey john65 - your welcome! Perhaps I should have mentioned that little quirk - I had the same problem when I 1st downloaded stuff from 'em - but I'm so familiar with it by now that I forgot to mention it.
Hope the manual helps!!
need help on Denon 685 VAS not working MikeMe Solid State 0 25th March 2011 10:55 PM
Worth fixing? Denon DRA-550... racedirector Solid State 6 2nd September 2010 03:26 PM
Denon DRA-35V widman Solid State 0 14th September 2009 12:52 PM
Problem with Denon DRA-455 smithy666 Solid State 0 29th June 2008 08:20 AM
Denon Dra-300 cathode_ray Solid State 1 8th November 2007 09:32 PM
Page generated in 0.08822 seconds (72.56% PHP - 27.44% MySQL) with 11 queries
