Anyone familiar with some high voltage low power bjt based amplifiers?
I'm looking for some common-emitter circuits that work with a VCC of about 400V. I can't even find any V/I graphs to compute loadlines for them and everything I've tried has some problems clipping. |
#2 |
KSP94 - 400V
http://www.fairchildsemi.com/ds/KS/KSP94.pdf
lineup |
#3 |
Um, there is no Vce/Ic graph!?!?!
#4 |
hmmmm i smell online psu .... and thread closed very soon .....
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#5 |
second breakdown is the big problem with bjt you may need 2-3x rated V for any current at all in SOA - some bjt for CRT drive are still made but fewer as time goes on, some have been desinged for sw mode ps too
2SC3183 |
#6 |
sakis: this has nothing to do with a psu. It is for a voltage amplifier.... i.e. the CE thing I mentioned. So you should get your nose checked...
jcx: Don't let sakis lead you astray... this has nothing to do with power. (I'm not sure what part of high voltage low power he doesn't understand) I'm simply wanting to replace a tube fx section with a solidstate version. The cathode follower is no problem but the common cathode is. I can't find any information on do this at such a high voltage. I'm kinda pushing it in any case but I simply need some voltage amplification to drive the PI to get enough power output from the amp. (I'll use a follower after the amplifier to actually drive the PI) I know it's not impossible to implement such a replacement circuit as I've heard of ss tube replacements. |
#7 |
High voltage low power... look at CRT line timebase output transistors. Generic types such as BU508, BUT11 etc. Low gain but would be very rugged I imagine for your application even if they didn't always seem it in TV's lol. There are countless such devices... just beware that many incorporate a high speed recovery diode (eg BU508D).
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#8 |
Mooly: I'm kinda looking for more info. Are these devices and other "high voltage" bjt's, mosfets, and igbt's used very similar to the low voltage case with just a scaling up of resistors or are their a lot of issues that makes it much more difficult?
e.g., if I have a 600V IGBT and I hook it up as a CE amp with the appropriate resistor values and bias should I expect to get a decent amplifier? (maybe somewhat non-linear but would it work or would I create a subminature black hole that will suck in my left testicle?) |
#9 |
There is no derating graph either. It does state that it is complementary to KSP44, and it has a SOA plot. IMO TO-92 w/out heat sink should operate no more than 60% Pd and given the voltage in this case, <40%. 1mA @ 350V would be pushing it a bit I think. Might have to use multiple paralleled devices....
![]() Seems strange to use a PNP device to substitute a valve. Is this some sort of feedback pair arangement?
All the trouble I've ever been in started out as fun...... |
#10 |
Maybe transistors suitable for lighting ?
| Why high voltage Fets when low voltage types gives less distortion? | Circlomanen | Pass Labs | 21 | 9th December 2009 09:43 PM |
| High linearty low-power BJTs and Class A headphone amp | percy | Headphone Systems | 24 | 27th July 2009 05:00 PM |
| Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. | kimbal | Tubes / Valves | 4 | 11th May 2009 08:05 PM |
| Toshiba JFETs BJTs Sanken BJTs | Praise! | Swap Meet | 5 | 14th February 2004 06:45 AM |
| Page generated in 0.14252 seconds (73.08% PHP - 26.92% MySQL) with 11 queries |
