#21 |
Hi Dan,
Always test at full volume when these controls are present. Balance controls can also be configured as reversed volume controls between the two channels. Once I had a similar problem in something, I forget the make and model. It turned out to be a piece of metal inside the volume control! Go figure, just goes to show you that you have to keep your mind and eyes open. So, check the amount of play in the bearings on all controls. If it's sloppy, the control should be replaced. Also pay attention to the solder connections on all controls and switches. Once you're done all that, pay attention to the wires connecting the various small PCBs to the main board. I'm talking about removing the solder, cleaning the leads and soldering these in again. -Chris
"Just because you can, doesn't mean you should" © my Wife |
| Krell amp with channel imbalance | Johpat | Solid State | 0 | 31st October 2010 05:49 PM |
| channel imbalance!!!! need help | tubo | Tubes / Valves | 5 | 10th December 2009 06:30 PM |
| Rotel RB-985 THX 5 channel amp | Rightbrained | Swap Meet | 4 | 27th November 2009 10:12 PM |
| Problem with Rotel RB-985 MKII 5 channel home cinema amplifier... | hoppaz | Solid State | 2 | 9th April 2009 08:04 AM |
| Rotel RC-850 Pre Amp + Rotel RB-870BX | bleachershane | Analog Line Level | 4 | 9th February 2009 11:20 AM |
| Page generated in 0.08624 seconds (64.38% PHP - 35.62% MySQL) with 10 queries |
