how to dim an LED
how to dim an LED
Old 21st July 2011, 11:57 PM   #1
jimbo1968 is offline jimbo1968  United Kingdom
Default how to dim an LED
sorry for off-topic, but I know someone here will know the answer.
I just bought a cambridge audio P500 amplifier, the single green LED is way too bright.
What size resistor should I put in series to dim it?
'Really dim' is what I'm aiming for.
If you need to know the voltage I will measure it.
thanks
Old 21st July 2011, 11:59 PM   #2
Andrew Eckhardt is offline Andrew Eckhardt  United States
Nobody knows what really dim is going to take, but you'd be off to a decent start by finding the value of whatever dropping resistor is currently in series with it and replacing it with 4 or 5 times the resistance.
If you need it dimmer add more resistance.
Old 22nd July 2011, 12:11 AM   #3
Thanks,
I haven't opened it yet, but from this picture it looks like an easy job. even for a mechanical engineer.
Someone will probably tell me the resistor value before I can measure it
Old 22nd July 2011, 12:15 AM   #4
danFrank is offline danFrank  United States
how to dim an LED
Brown, Black, red? 1K ohms. Just put a small 5K or 10K trimmer in series with the resistor, adjust till you get the desired brightness and then forget about it.
Daniel
Old 22nd July 2011, 12:19 AM   #5
Good idea. I can probably find one of those.
how to dim an LEDHide this!Advertise here!
NAD Display Very Dim DQ828 Digital Source 28 2nd July 2014 09:19 AM
Very dim digital readout srinath Solid State 13 3rd April 2011 08:02 AM
