Old 21st July 2011, 08:32 PM   #1
Default Vu meter, questions
Hi!
Im new to lm391x
Im planing to build several vu meters for cubase music studio.
I want the output from a midi source to go in to the input of an lm3915 and lm3916 extended range meter
My question to u people. can the input come from a dc source or do I need ac.
And is it possible to change the input to 3,12v for full scale instead of 7,8v
Cant find the documents in swedish. hard to the english terms.
thanks
/Thomas
Old 22nd July 2011, 08:45 AM   #2
Hi Thomas,
the LM391x chips are happy with DC or AC. The internal comparitors switch at DC levels, so no problem, there.
Sandy
Old 22nd July 2011, 09:38 PM   #3
Hi!
Thanks sandy!
Now i have to ask one more thing. The T1 transformer. what kind do i need, can i make it my own or can i find it on ebay for good price.
Thomas
Old 22nd July 2011, 09:54 PM   #4
Tajzmaj is offline Tajzmaj  Slovenia
It depends in which mode you will use meter. Bar or dot........but for an example if there you have 20 leds and each draw 20mA you will need some 0.5A of current. If you want to build several meters it is good idea to make one pwr supply for all. Some 7-10VDC will work and chips will run cool....
Regards, Taj
Old 23rd July 2011, 01:23 AM   #5
jaycee is offline jaycee  United Kingdom
You could also use any pre-made 12V supply that supplies enough current.
Changing the input voltage scale would simply be done with a potential divider. This is actually what the second IC has on it, with R3/R4.
Old 23rd July 2011, 08:57 AM   #6
Ok. I understand.
Im planing to build 26 vu meters in bar mode. on three pcb´s 8, 8, and 10 on the last one.
494 leds. So then i can use a transformer from 230v ac to 6.3v ac or do i need more.
More questions
1n4001 do i have to change the value on them and the 2.2uf?
The formel. R3/R3+R4= 0.158= - 16 db. Is it 158 ohm?
Thomas
Old 23rd July 2011, 12:04 PM   #7
On my experience some 7-10 Vac is batter if you want to build some regulated psu. You will have some problems if you use just simple gretz and capacitor psu because cap voltage will drop when all vu meters will go to full scale.....so regulated psu is needed......
uf I barely see what I'm typing. I'm sitting at the sea shore.......and sun is very bright....
Best regards, Taj
Old 15th August 2011, 03:28 PM   #8
Sounds nice with the sea and sun.
I will do as u say tajzmaj, 7-10volt ac maybe 12v. without capacitor?
But do I need resistors for the leds, cant find it out in the paper.
I have a lot of them wich works good with 12v, if i need em maybe better to drive them by 12v insteed.
regards, Thomas
vu meter surfstu Tubes / Valves 14 24th March 2009 09:03 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
vu meter help cowanrg Parts 12 2nd September 2004 05:21 AM
VU meter nbcd Solid State 5 16th November 2003 09:02 PM
vu meter karma Pass Labs 17 19th April 2003 11:00 PM
Page generated in 0.10151 seconds (73.12% PHP - 26.88% MySQL) with 10 queries
