Current-mirrored Folded-cascode
Old 17th January 2002, 02:03 AM   #11
paulb is offline paulb  Canada
Watch for Grey in Analog Science Fiction and Fact, the upcoming May or June issue.
He's too humble to tell you about it himself.
Old 17th January 2002, 03:00 AM   #12
jam is offline jam  United States
jam's Avatar
Grey,
How about " The objective monster from down under that ate Elvis", as a possible title for you new book. Heh !
Jam
Old 17th January 2002, 03:14 AM   #13
jam's Avatar
Michel,
Maybe you could tell us which issue of Electronics World the article will be in?
A folded cascode models as a single stage and adding a follower you have a two stage amplifier, close to a straight wire with gain, I suppose.
Nelson Pass, I believe, has used this approach in some of his designs.
Jam
Old 17th January 2002, 03:32 AM   #14
jam's Avatar
Michel,
Sounds like you are on to something. What is the open loop output impedence of the amplifier?
Jam
Old 17th January 2002, 03:46 AM   #15
jam's Avatar
Michel,
Just trying to get you to give up more information on the amplifier. You certainly have our attention.
Jam
I would also like to know if high feedback with resultant low distortion is your prime criteria for the design (straight wire with gain)?
Old 17th January 2002, 04:08 AM   #16
jam's Avatar
I cannot disagree with you there. You seem to share the same views, as I do, on amp design.
I shall be waiting at the edge of my seat ........
Thanks,
Jam
Old 17th January 2002, 06:11 AM   #17
GRollins is offline GRollins  United States
Rarely has a thread been started with so little content as this one...
Grey
Old 17th January 2002, 06:25 AM   #18
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
i'd agree... mind you i've probably started @ least one that had less content ..... i get Electronics World each month so i'm itching to see your design. I probably wont use it but it'd be nice to see a little 'proof of concept' info...
Old 17th January 2002, 12:11 PM   #19
jam's Avatar
Guys,
Let us not be too hasty to judge Michel. If he does not deliver, we can stone him later.
Michel,
Any chance of posting a conceptual (block diagram) of the schematic?
Jam
Old 17th January 2002, 01:30 PM   #20
Petter is offline Petter
Default X?
This is interesting, however -- is this not exactly what the NP X input stage does?
http://www.passlabs.com/pdf/susy.pdf (or better still original patent at http://www.delphion.com/cgi-bin/view...=pdf&MODE=fstv)
I am not quite sure what a transimpedance stage is. Perhaps a short explanation on this might be in order since my Horrowitz and Hill is not avaible for now.
Petter
Current-mirrored Folded-cascodeHide this!Advertise here!
Folded cascode headphone amp nelsonvandal Headphone Systems 266 28th March 2009 07:12 PM
folded cascode the_tool Chip Amps 1 27th June 2006 09:53 PM
Folded cascode question Won Solid State 3 11th January 2002 07:10 PM
