Hiraga 20W class A - Page 58 - diyAudio
Old 30th March 2012, 07:39 PM   #571
Hello triode
Please after you tested let us know how it work out. Thank you
I prefer the sound of the Fet, many years I was interested on that schematic but not with those old V-Fet.
Also one day I will test the LeMostre mosfet version.
I made the PC boards but now I'm busy with other project.
I post the schematic here if someone interested........
Greetings Gabor
Old 31st March 2012, 08:16 AM   #572
triode_al's Avatar
Originally Posted by gaborbela View Post
Hello triode
Greetings Gabor
That's a nice combination of Le Monstre and the Le Classe A variant of the Sony Farlington.
I plan to use HIT667, + HIT647 as drivers. That must be good enough for the input capacitance, there is no real current like with a BJT output.
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 31st March 2012, 10:48 AM   #573
post571.
the R9/R10 junction connects to the feedback node.
Does it need to?
What does this extra connection achieve?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 31st March 2012, 01:15 PM   #574
Hello Andrew
Probably a mistake, I have to take a look at the orig LeMonstre.
I didn't designed these circuit or worked on it.
All do I made the PC boards ready.
Thanks one more time
Greetings Gabor
Old 31st March 2012, 01:25 PM   #575
Hello
Yes it look like a error in the circuit com pare to the orig Monster!
Thanks one more time.
Now I have to pay att. on the PC board to...
The lay out need to be rescale when you printed out!
Greetings Gabor
File Type: png Hiraga-Monstre-Monster-Class-A-amplifier-schematic.png (31.2 KB, 675 views)
Old 31st March 2012, 01:31 PM   #576
Hello
I forget to attach.
Greetings
Old 31st March 2012, 06:51 PM   #577
I see the original connects the same two resistors to Audio Ground. Again the same question: does it need to?
regards Andrew T.
Old 31st March 2012, 07:15 PM   #578
Hello
Good question.I built that way a couple times, to be honest I never kept the Monstre more than couple month in my system.
I do not like that sound, to precise (almost clinical) with good CD sound OK but most of the time the sound is thin, not my cup of tea.
Greetings Gabor
Old 1st April 2012, 07:18 AM   #579
triode_al's Avatar
In the original the cascode bias goes to ground.
With due attenuation of the feedback (220 ohms/10 ohms Le Monstre and maximum signal of 10 peak) this means that the Vds swings one volt underneath the cascode. That is OK.
With a higher voltage, the Vds starts to swing more. At a certain point (like in the F5 cascode!) there is 5 volts swing on the Vds - to much imho, the whole sense of the cascode disappears, except for the dissipation/heat.
  • (The sonic reason is that it decreases the capacitances of the input JFets and makes them more transparent)
So Gabor,
My reasoned suggestion: connect the bottom of the bias divider to the 10 ohms of the feedback.
[The all BJT Le Classe A don't have a cascode]
Old 1st April 2012, 07:53 AM   #580
Hello
So you say to use the connection at the mosfet version it was correct. Connect to the ground!? Like the schematic at the post 571?
Please advise if I understand it well. All do I want to go a bit higher PS voltage. About 17V rail voltage but I still do not think that extra 5V will do 5V swing.
Greetings Gabor
Dynaudio + Hiraga Class A maartentje Multi-Way 7 30th April 2010 12:20 PM
Hiraga 20w AB class search? tadiam Solid State 0 18th April 2008 06:47 PM
Hiraga 30w PSU azoran Solid State 0 1st April 2007 03:32 AM
Hiraga 20W Class-A Geoff Solid State 8 5th November 2003 05:55 PM
Hiraga Class-A Geoff Solid State 14 17th July 2001 04:58 PM
Copyright 1999-2017 diyAudio
