Hiraga 20W class A
Hiraga 20W class A
Old 28th September 2011, 07:06 AM   #501
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by danieljw View Post
Hi Al,
Sounds like a good idea
-Dan
Hi Dan, I finished a F5 clone the last days, with these big transistors. Big fun!
Hows life behind the soldering iron, any time left?
albert
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 28th September 2011, 03:56 PM   #502
gaborbela is offline gaborbela  Canada
Hello
I didn't tested yet, I'm working on two speaker project.
Greetings gabor
Old 20th October 2011, 12:18 PM   #503
moochinazz is offline moochinazz
hello guys, i've alsto tried to build my 20w hiraga version. but i'm facing a problem. i have 12v in speaker output.iwhere should i look a problem for? thak you in advance
Old 20th October 2011, 01:18 PM   #504
Pano is offline Pano  United States
Pano's Avatar
Hiraga 20W class A
The only time I've seen that happen was when an output transistor fried. Is it 12V positive or negative? That should help you know which is bad.
It may not be a bad transistor, just one that is not conducting because of a bad connection or something wrong upstream.
I'm sure someone else will have other, better, ideas.
Take the Speaker Voltage Test!
Old 20th October 2011, 02:25 PM   #505
12 is positive
Old 20th October 2011, 02:44 PM   #506
Pano's Avatar
Hiraga 20W class A
Both channels, or just one?
Old 20th October 2011, 03:01 PM   #507
just one, becaus ive built only one channel for testing
Old 21st October 2011, 12:00 PM   #508
forgot to tell that output transistors i use are 2sa1302 and 2sc3281. i've replaced a fried transistor 2sa632, the output voltage is 1,7v and the 5w resistors heat up very badly. oh, and this is schematic, that i've used www.tcaas.btinternet.co.uk/hiraga3fig1.gif
Old 21st October 2011, 01:59 PM   #509
triode_al's Avatar
Moochinaz,
the board is for testing only I understand.
What I did is take out a 1k1 collector resistor and replace it with a 2 k potmeter: this will overcome imbalance in the input quad. A likely source.
Old 21st October 2011, 02:00 PM   #510
which one 1,1k?
Hiraga 20W class AHide this!Advertise here!
Dynaudio + Hiraga Class A maartentje Multi-Way 7 30th April 2010 12:20 PM
Hiraga 20w AB class search? tadiam Solid State 0 18th April 2008 06:47 PM
Hiraga 30w PSU azoran Solid State 0 1st April 2007 03:32 AM
Hiraga 20W Class-A Geoff Solid State 8 5th November 2003 05:55 PM
Hiraga Class-A Geoff Solid State 14 17th July 2001 04:58 PM
