Hiraga 20W class A - Page 48 - diyAudio
Old 6th February 2011, 10:02 AM   #471
triode_al's Avatar
Originally Posted by danieljw View Post
All good al,
Have you had a listen to the Hiraga stuff before ?
Yes Daniel, indeed have heard them on the large Onken loudspeakers with horns, at the 'old' Maison de l'Audiophile in Paris, with William Walther in charge.
And, - Yes, I have tempted to build it for my ESL, but never succeeded far enough (own choice of components, having all bias resistors adjustable till there is a DC equilibrium without feedback applied yet isn't easy). Now I saw the board from the German ebay I might be tempted again to experiment
I do have the 8W (which is not the threads' topic but discussed anyway).
albert
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 6th February 2011, 11:25 PM   #472
danieljw's Avatar
Send a message via MSN to danieljw
I wish I had heard the setup you heard with the onkens do you have a photo of the 8w to share with us ? What eBay link was it you saw - it sounds interesting
-Dan
Sent from my HTC Desire using Tapatalk
Old 12th February 2011, 08:41 AM   #473
triode_al's Avatar
Default 8 W Hiraga implementation
Hi Dan,
here you go:
this is my second implementation with regulated power supply. The first one had passive and in total 12 of those large capacitors.
Note the extra large 1 ohm resistors! They still get hot.
I have decoupled the transistors in the cascade stage with solid tantal caps of 27 micro farad.
I have noted that the quality of the feedback set is very important.
regards
albert
Old 12th February 2011, 09:32 AM   #474
Originally Posted by jeepy View Post
-> Also here + 50W!
Mes réalisations en DIY audio
ah this is not a Hiraga 50+50, but a Kaneda 50+50.
Hartmut
Old 12th February 2011, 09:34 AM   #475
Hiraga 20W & 30 W - Last official technical informations published in l'Audiophile in 1985. Unfortunately in French but fortunately not a problem for me.
On en parle n°34 : modifs ampli Hiraga 20W, tweeter technics 5HH10 ...
a friend of mine had both versions (not DIY, but commercial versions), the 30W sounds much better, more transparent and powerful at the same time.
Hartmut
Old 12th February 2011, 09:47 AM   #476
what is the power rating of these extra large 1 ohm resistors when you choose to use them without a heatsink?
What is the Rth j-a of the resistor without a heatsink?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th February 2011, 09:55 PM   #477
danieljw's Avatar
Hi Al,
Thanks for posting the photo that is a nice build. large caps, solid earth and decent heat sink
Old 13th February 2011, 09:09 AM   #478
triode_al's Avatar
Hi Andrew,
these resistors are 50W but in air this is lower. I can't find the thermal resistance in free air - just the derating, which is 35% in such a closed box.
Of course the current is some 750 mA, but the inside of the cabinet reaches easily 35 degrees, and the resistors are some 45 degrees to the touch.
albert
Old 13th February 2011, 11:29 AM   #479
danieljw's Avatar
45°C is well within the limits for these
the last two monstres i built one used 5W wire wound at 0.6A and they ran hot to touch.
one used 5W metal film they ran hot to touch also.
le class A is a little nastier running at 2A-2.5A but the whole amp runs hot after an hour or two it is close enough to thermal equilibrium and sounds really nice.
I wish you could still get the sony vfets..... a vfet Monstre would be great....
-Dan
Old 13th February 2011, 04:11 PM   #480
triode_al's Avatar
-Dan
Well, I have a batch of original Toshiba 2SJ55 and 2SK175 - how would that do? Absolute thermal stability and a veritable hot - hot monstre. What do you think?
albert
Dynaudio + Hiraga Class A maartentje Multi-Way 7 30th April 2010 12:20 PM
Hiraga 20w AB class search? tadiam Solid State 0 18th April 2008 06:47 PM
Hiraga 30w PSU azoran Solid State 0 1st April 2007 03:32 AM
Hiraga 20W Class-A Geoff Solid State 8 5th November 2003 05:55 PM
Hiraga Class-A Geoff Solid State 14 17th July 2001 04:58 PM
Copyright ©1999-2017 diyAudio
