Hiraga 20W class A
Hiraga 20W class A
Old 2nd February 2011, 01:03 PM   #461
Telstar is offline Telstar  Italy
Originally Posted by gaborbela View Post
You can't double the output transistors !
It is a built up darlington power stage .
Greets
If you are still around, could you post the schematic of Selectronic's Profet amp?
They sell only finished units now.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 2nd February 2011, 02:25 PM   #462
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by Telstar View Post
This is true, but depends on the output transistors used. I guess that you are using some of the biggest ones from on semi, which have the sweet spot around 1.1A, but also like more VOLTAGE (unless you cascode them).
I didnt check the datasheets, but I'm pretty sure that the original ones chosen by Hiraga were doing their best at 20W output power, or he would just have proposed a 30W amp
The outputs chosen were not very high powered; the maximum power depends on the heatsink thermal resistance.
Additionally: the current amplification is matched with the driver transistors, such that this becomes a combo that performs well.
Even the input pairs must be 'better than' the commonly proposed BC559 type, as the flat shelving of the amplification is needed, that reacts to a difference in the Vce-difference. Hiraga spent quite some time in matching, each choice is tricky.
albert
SPU --> tube MM/RIAA;
Pass buffer -->300B SE Anzaï Zaïka; --> FE103 sigma TQWT
Old 2nd February 2011, 02:35 PM   #463
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Hiraga 20W class A
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 2nd February 2011, 02:39 PM   #464
triode_al, you're right: Hiraga "matched" all transistors.
BTW, I have found these PCB on sale, which seem good:
Leer PCB Super Class A Verstärker Hiraga "L Audiophile" su eBay.it Verstärker, High-End Audiogeräte, Audio Hi-Fi
This scheme has been posted in this thread.
Old 2nd February 2011, 03:15 PM   #465
Pano is offline Pano  United States
Pano's Avatar
Hiraga 20W class A
I can confirm that, as I ran a slightly higher voltage and power on my first build and killed the output transistors (and a 12" woofer). The heatsinks were big. Be careful with the bias.
Old 3rd February 2011, 02:29 AM   #466
danieljw is online now danieljw  Australia
danieljw's Avatar
Send a message via MSN to danieljw
Hi guys,
There is two versions of the class a you can get 30W with resistor and ps voltage changes. The original chassis will run very hot in this situation. The bias makes a big difference. 1.5A to 2A is nice from my experience with this one
Sent from my HTC Desire using Tapatalk
Old 3rd February 2011, 03:47 PM   #467
triode_al's Avatar
I understand some power this little monster from a 12 V regulated supply.
the original Le Monstre (which I built with the selected transistor set from the Maison de l'Audiophile) is intended to run from lead acid batteries as well. This implies that the Vb is higher than 12 V: between 12,6 and 13,2 V is useful.
This slightly more than one volt difference makes a difference in power consumption (current) and details.
albert
Old 6th February 2011, 02:40 AM   #468
danieljw's Avatar
Hi Albert, Le monstre is a different amp, this thread is for le class A
Old 6th February 2011, 09:51 AM   #469
triode_al's Avatar
Daniel, You'r right. I'm shooting from the hip, apparently. albert
Old 6th February 2011, 10:42 AM   #470
danieljw's Avatar
All good al,
Have you had a listen to the Hiraga stuff before ?
Hiraga 20W class AHide this!Advertise here!
Dynaudio + Hiraga Class A maartentje Multi-Way 7 30th April 2010 01:20 PM
Hiraga 20w AB class search? tadiam Solid State 0 18th April 2008 07:47 PM
Hiraga 30w PSU azoran Solid State 0 1st April 2007 04:32 AM
Hiraga 20W Class-A Geoff Solid State 8 5th November 2003 06:55 PM
Hiraga Class-A Geoff Solid State 14 17th July 2001 05:58 PM
