Hiraga 20W class A
Hiraga 20W class A
Old 1st October 2009, 03:01 PM   #381
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
Default Hi Masag1!
Originally Posted by masag1 View Post
Hello,
here is the top an the bottom layer.
Sam
That what I talking about!
And where Schematic?
Regards zeoN_Rider
Old 1st October 2009, 03:58 PM   #382
masag1 is offline masag1  Germany
I know what you meant, zeoN_Rider
Schematics will follwow, cannot find in the moment.
Sam
Old 1st October 2009, 05:15 PM   #383
R.I.P.
Originally Posted by AndrewT View Post
can you measure the voltage without a load?
Then measure with a low current load, eg. bias set to 500mA and then voltage when bias set to 1000mA.
Originally Posted by Glogov_Kolac View Post
I have been measured with no load, after rectifier bridge, when both (left and right) channels are disconnected.
what is the secondary Vac when the rectified & smoothed =18Vdc
You have smoothed the rectified AC? or not!!!
regards Andrew T.
Old 1st October 2009, 06:14 PM   #384
Glogov_Kolac is offline Glogov_Kolac  Serbia
After rectifier I measure 18VDC. With smooth circuit(capatitors) the measured value is the same!
Old 1st October 2009, 11:50 PM   #385
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
Hi Sajti,
I would never use the KSC2690/KSA1220 as VAS
They do a better job in current stages.
But this amplifier has different requirements, because that stage has to provide the base current of the output devices. The low Ic max types has significant beta drop with high Ic. The 2SC2911/2SA1209 B drops from 250 down to 100 at 100mA.
Very true. It`s kind of a problem. Such currents place them far outside their linear zone. In my view, the types with specified Icmax=50mA, should not be used at more than 10mA. As stated, video transistors are meant for high voltage-low current operation. Look, there´s much more to say about this issue.
The speed is equal. Only the capacitances are higher (19pF vs 4pF). This is the only drawback
They have fundamentally different properties, maybe not apparent from data sheets. That`s what I`m desperately trying to point out.
I don't know what do You mean with coarse types? The types I recommend is not for switching.
Western manufacturers have been developing semiconductors almost exclusively with switching performance in mind.
Old 1st October 2009, 11:55 PM   #386
stoN_Cold's Avatar
Sam
OK!
I'll still wait!
Regards zeoN_Rider
Old 3rd October 2009, 10:14 AM   #387
Tutto completo
My friend sent me the schematics for DC protection
Sam
Old 11th October 2009, 08:55 PM   #388
sandyhooker is offline sandyhooker  United States
sandyhooker's Avatar
I have purchased boards for what appears to be a Hiraga Le Monstre with 20-22 volt rails . I've poured through this thread and two others only to find wide ranging opinions regarding semiconductors. The parts list that is associated with the boards calls for 2n3055/mj2955 outputs ,2sd756/2sb716 drivers and 2sa872/2sc1775 cascode. The venerable j170/k74 jfets are at the input.
Two concerns; the 2n3055 combo which has been all but forgotten and the 2sb716 which is the only small piece I cant seem to buy.
The threads indicate other possibilities both for drivers and outputs.Would anyone care (I hope so) to offer alternatives based on actual experience.
I really have spent time looking through the threads and am not looking for an easy way out.
Thanks so much.
Old 11th October 2009, 09:24 PM   #389
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Hiraga 20W class A
I bought and built a Danish kit version many years ago
Very serious kit with absolute top of the top quality parts, unobtainaly to ordinary people, back then
I dont know if anything was changed from the original, but seems to me transistors are different
The outputs were with green housing, so I suppose they were all genuine Toshiba
I have specs on other used parts too, if needed
btw, it worked flawlessly, very good, still regret I sold it
Old 11th October 2009, 10:29 PM   #390
danieljw is offline danieljw  Australia
danieljw's Avatar
Send a message via MSN to danieljw
Thanks so much.
Hi Sandy,
This is not a Le monstre it is the 20W class A... i think perhaps you will find much better results with different output transistors than 2N3055/2955
PS: I have some 2sd756/2sb716 left PM or email danw1million@hotmail.com so i dont annoy anyone on here.
-Dan
Hiraga 20W class AHide this!Advertise here!
Dynaudio + Hiraga Class A maartentje Multi-Way 7 30th April 2010 12:20 PM
Hiraga 20w AB class search? tadiam Solid State 0 18th April 2008 06:47 PM
Hiraga 30w PSU azoran Solid State 0 1st April 2007 03:32 AM
Hiraga 20W Class-A Geoff Solid State 8 5th November 2003 05:55 PM
Hiraga Class-A Geoff Solid State 14 17th July 2001 04:58 PM
