I am building single ended mosfet amplifier. I am not electrical engineer. How do I adjust idle current? Also would it be possible to convert the output stage to DC coupled version? Or do you know some better schematics of single ended output mosfet stage which inverts the phase? Thank you. |
#2 |
#3 |
I know that thread as I have already built two moskidos. But that thread is about push-pull variant mainly.
I have spare parts and building this single-ended version as headphone amplifier. |
#4 |
...... try this for final headphone amplifier and Aikido in front like preamplifier
HeadWize - Project: The Zen Headphone Amplifier by Marcello Pellerano . I have use marcelo's amplifier with Sennheiser HD555 from some time with good results . |
#5 |
But does this Zen headphone amplifier invert the phase? Because aikido stage already inverts.
#6 |
I found it, it does invert.
#7 |
Banned
Common cathode / source / emitter stages invert the phase. Why is it important?
#8 |
Idle current should be adjusted by the upper resistor in CCS mosfet (150k).
Should I make source resistor higher value (like 2 ohm) as it woudl be better for headphones? Do you know why is feedback taken before output capacitor and not after as it would reduce output cap distortion? Last edited by kacernator; 21st July 2011 at 06:48 AM. |
#9 |
Banned
You could change the 0.56 Ohm resistors to around 10 ohms. Roughly I = 1.2 / R
Feedback does not reduce cap distortion. What tubes are you having? |
#10 |
I am using 6SL7 and 6SN7 tubes. Alternate option is to use ECC83 and for output ECC82 (or ECC88). If no feedback would be used, you can use lower gain input tubet, but I think it will sound better with feedback - will see after the build is finished, it will take one week or so, as I have little time in next few days.
I will use 2.2 Ohm source resistors and adjust the upper resistor in CCS to set current. |
| F5 meets Buzquito | juma | Pass Labs | 119 | 19th November 2011 03:21 PM |
| The Edcor meets the 6AV5 | tubelab.com | Tubes / Valves | 119 | 8th September 2008 01:31 AM |
| Old meets new but can this be solved? | barchetta | Pass Labs | 4 | 11th March 2007 07:29 PM |
| Old Meets New | philipbarrett | Tubes / Valves | 3 | 22nd August 2005 12:03 AM |
| Page generated in 0.13138 seconds (68.54% PHP - 31.46% MySQL) with 11 queries |
