Leach Low Tim frontend tweak - Page 2 - diyAudio
Old 23rd July 2011, 01:14 PM   #11
djk is offline djk
djk's Avatar
They do.
But the ear is an interesting instrument, after a while it can 'tune out' certain sounds, ignore them if you will. Whenever I play in a new venue it always takes a while to get used to the room. After a while you start thinking to yourself 'it really doesn't sound as bad as what I though originally'.
Candidates for the Darwin Award should not read this author.
Old 26th July 2011, 04:20 AM   #12
I have two more spare PCBs for my mods. I will assemble one and attempt the mods on it. But one thing is sure - I am going to remove the protection circuit on these assembled boards as I will use speaker protection circuit.
Gajanan Phadte
Old 26th July 2011, 05:52 AM   #13
djk is offline djk
djk's Avatar
The foldback current limiting on a Leach is to protect it from shorts and being driven hard into clipping on low impedance loads. A friend can make his produce 'farting' sounds when driving more than 6dB into clipping on a 2Ω load. Other than that, I have never heard the foldback limiter.
If you mean a DC protection relay, that's a different function. I prefer both.
Old 26th July 2011, 06:49 AM   #14
Yes, I mean the dethump and dc protection circuit with a relay.
I intend to protect the speaker only and the amp should sound good.
As far as the frontend bias goes, I find that the consensus is that it sounds good.
Can the zener noise be reduced if I make zener from transistors.
Gajanan Phadte
Old 26th July 2011, 08:38 AM   #15
djk is offline djk
djk's Avatar
No, the reverse BE junction is just as noisy.
Transistors can be used when you need a ~7V zener, you can but a cheap transistor for less than a zener.
Audio Amateur had a noise generator project the amplifier a BE junction noise.
On the other hand, Nelson Pass used the BE junctions with 0.1F in many of his designs.
Old 26th July 2011, 09:12 AM   #16
Rapid sell the small Zeners at between 0.70 to 1.59 per hundred.
I can't get transistors that cheaply.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th July 2011, 09:28 AM   #17
djk is offline djk
djk's Avatar
Surface mount 2N3904 go for $1.04 per hundred to about $2.16, depends on the vendor and total quantity.
I buy through-hole transistors at $3.00 a hundred.
Old 26th July 2011, 09:37 AM   #18
I get my transistors free from discarded boards and I prefer them as they r not fakes. Any damn transistor is mostly a fake here.
Gajanan Phadte
Old 27th July 2011, 04:39 AM   #19
Zeners are noisy. What if I replace R13 with 317L and R14 with 337L.
Taking all the care for selection of components around these regulators, shall I have improved the performance.
They will regulate the supply to 40 V.
Gajanan Phadte
Old 27th July 2011, 04:43 AM   #20
The zeners will be gone.
Higher Power Low TIM Leach Stormrider Solid State 34 13th December 2016 10:25 PM
Leach Low TIM 4.5 bias problem Craig405 Solid State 9 27th June 2010 11:04 PM
Qestions about the Leach low-TIM amp Ryan_Mc Solid State 3 4th December 2008 01:32 AM
Testing Leach Low TIM ptah Solid State 27 21st December 2006 04:39 PM
Leach Low-Tim Amp Finished Dave S Solid State 5 1st March 2005 07:07 AM
Copyright 1999-2017 diyAudio
