#11 | |
![]() Real opinions, ... thanks |
#12 |
Correction for error between VAS and output will be driving lower MOSFET 4.5x as hard.
Not so different from single ended with a CCS. I mean, top MOSFET is driven and active, definitely not a constant current. But not nearly so active as the bottom MOSFET. If the above behavior is acceptable: No, they don't need to be the same. And you will run out of headroom on the bottom much sooner if you fix it, so there is at least one good reason not to fix it. Last edited by kenpeter; 21st July 2011 at 07:56 PM. |
#13 |
please go to "quasi" power amp under development
there is perfectly NMOS working up to 1 KW RMS @ 4 OHM universal circuit you can drive MOSFETS or BJTs have build some pcs. and works perfectly with great sound can email schematic and PCB layout |
#14 |
hello nmos can you send me pcb drawing of 1kw@4ohm man.harpreetsingh72@gmail.com thanks
| Maplin 100W mosfet amplifier - power supply problem | HBrunt | Solid State | 8 | 21st October 2011 01:04 AM |
| Tube/Mosfet 100W Hybrid Amplifier | apexaudio | Solid State | 132 | 22nd April 2011 08:20 PM |
| 100w amplifier | blindmole | Solid State | 40 | 11th April 2011 09:25 PM |
| Good ~100W amplifier | percy | Solid State | 14 | 10th October 2004 12:31 PM |
| 100w Mosfet amp | m60gpmg | Solid State | 11 | 14th January 2004 07:48 PM |
| Page generated in 0.08016 seconds (63.82% PHP - 36.18% MySQL) with 11 queries |
