is it possible that you can power a 200 watts mosfet amplifier with a switching mode power supply even without battery?
#2 |
just another
I assume you are asking because often switch mode power supplies are used in car audio applications running off a 12V battery. There is no reason a switch mode supply running off mains cannot be used to power a 200W amp provided the power supply is designed to provide the required voltage and current.
edit: not being experienced in such things I would add the caveat that noise might need to be considered and would probably be more or less of an issue depending on the PSRR of the particular amp. Tony. Last edited by wintermute; 16th July 2011 at 01:28 AM. Reason: add psrr comment |
#3 |
pyramid 12v power supply | eBay
I recommend buying twice the number of watts the amplifier is rated at.
Candidates for the Darwin Award should not read this author. |
| Quickie woodworking question! With bonus shellac question... | head_unit | Construction Tips | 13 | 12th September 2010 05:38 PM |
| do i REALLY need a crossover?? and an amp question. and an ohm question | legendaryfrog | Multi-Way | 4 | 29th October 2006 01:39 AM |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| Capacitor Question /question on cap | TunaFish | Tubes / Valves | 14 | 12th January 2004 02:23 AM |
| Page generated in 0.08638 seconds (61.13% PHP - 38.87% MySQL) with 10 queries |
