Old 15th July 2011, 11:31 AM   #1
Question Krell KSA-300S cliks off
Gents
I have in my lab a Krell KSA-300S for repair/restore.
It switched on, then clicks a few times, an the back to standby, owner reportet a small smoke signal from the back of right channel board.
Investigation showed, that a cap. (C24) had a leak, and electrolytic fluid shorted a track leading to anode D12!
So i decide to clean, and recap. the entire amp. but it still presents the same behavior: it sucks in a lot of power charging the main caps. and the cicks a few times with the small relays, and the back to st.by
Removing/disconnecting the right channel, the amp powers up and works fine on left channe alone.
I think some problems persists in the bias setting system, but this amp is not straight forward for reverse engeneering, (there is a microcontroller and its sofware involved).
Does anyone have experiance wit this unit, or is anyone able to provide a schematic?
Any hint or clue is much appreciated
krell ksa 300s right channel dead maybe transistor problem?? yipyip55 Solid State 24 27th April 2012 09:31 AM
Krell KSA-300S Chassis Restoration john65b Solid State 5 7th June 2010 03:00 PM
krell ksa 5 Zen Mod Solid State 44 7th June 2010 07:39 AM
Krell KSA-300S will not turn on fcel Solid State 48 10th November 2007 05:20 PM
Page generated in 0.05040 seconds (73.27% PHP - 26.73% MySQL) with 10 queries
