Hi all new here...
I have a ultra low noise pre-amp that am experimenting with and need to switch a capacitor in and out without extra noise. Just switching the one leg of the cap will do. I dont wish to use a simple on/off toggle switch with leads connected as the leads will act as antenna and induce noise.. Would prefer it as IC based smd or other wise to do the switching .. but this device should not induce noise of any sort. The other thing is it has to be switched as I need to close up the unit and take it away from any noisy environment.. this is why the switch is needed... as I am testing as to what value of capacitor is needed. any help on this ?? The unit is running on 7.5 volts and is converted to 12 v and 5 v dual. ross |
#2 |
How do you expect anyone to help you without telling us what the key switch requirements are?
#3 |
#4 |
Use a reed relay or a very small PCB relay.
Glenn. |
#5 |
If there is the slightest voltage differential on the capacitor vs the points in the circuit it is being switched into then you will get a "click" noise.
My prefered option would probably be something like a jfet as the switching element.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
| AC to DC circuit switching using function generator, need help | jegandren | Power Supplies | 11 | 6th August 2008 09:36 AM |
| switching circuit | rfarn | Parts | 6 | 14th June 2008 02:03 PM |
| Trouble with speaker protection circuit (Randy Slone's circuit) | whalefat | Solid State | 3 | 13th April 2005 10:13 AM |
| Relay switching circuit please | jnewbold | Solid State | 10 | 3rd March 2005 06:39 AM |
| Switching circuit help needed | trustalbini | Tubes / Valves | 15 | 26th July 2003 08:23 PM |
| Page generated in 0.09421 seconds (71.83% PHP - 28.17% MySQL) with 10 queries |
