Old 14th July 2011, 04:43 PM   #1
TylerDurden's Avatar
Default Powering on my LCD causes my amp to hum through the speakers
I have managed to narrow down the cause of the humming through my speakers to my TV. When it is switched off there is no hum, but when I turn it on there is a loud background hum.
This is a problem because the TV is actually the one and only source in this situation.
Can anyone help me get rid of it?
Old 14th July 2011, 05:41 PM   #2
Bone is offline Bone  United Kingdom
Youve probably got an earth loop. Disconnect the earth (common) on one end of the connecting signal cables.
Old 14th July 2011, 05:42 PM   #3
Thanks for your input, but I don't really follow what you mean. What should I disconnect and where?
Old 14th July 2011, 05:57 PM   #4
Mooly is online now Mooly  United Kingdom
Mooly's Avatar
Just start again... is the TV connected as a signal source to the amp ? Not sure if you meant that or source of the hum
If the first, how is the TV connected. Is it with phono leads ?
An earth loop is where there is more than one ground return usually via mains leads etc.
Is it a hum ? which is a deep and very pure tone, or is it a buzz with harsher rasping sound ?
A simulation free zone. Design it, build it, test it.
Old 14th July 2011, 06:03 PM   #5
I have an HTPC and a Freeview PVR attached to my TV via HDMI. The TV then connects to the amp from the TV-Out jack to Phono leads.
If I was to choose I would probably call it a buzz, it isn't a deep tone, but a mid to high harsher sound.
Thanks for your input.
Old 14th July 2011, 06:25 PM   #6
Mooly's Avatar
This probably isn't going to be easy to pin down.
Is this buzz affected by the setting of the volume control or is it present even with the volume on minimum ?
Very difficult without seeing the set up.
I would initially have the amp and TV connected but NOTHING else. That means no aerials... no PC, no nothing , just the audio lead between the two and see if the buzz is still present when the TV is on. Then try connecting items in the chain one at a time.
Old 14th July 2011, 06:38 PM   #7
The buzz is not there when volume is on minimum.
It is there with nothing but the audio leads between the TV and Amp are connected.
Old 14th July 2011, 06:47 PM   #8
Mooly's Avatar
OK. The next thing, and this might sound strange, is too just connect the outer (which is the ground) of the phono leads to the amp but not the signal (which is the middle pin). That's easiest done by unplgging L and R and then just hold the outer part of one or the other so that it touches the metal body of the phoo socket on the amp.
If you try that start with the volume on minimum and see if the hum still there as you turn the volume up.
If not then things get more complicated... it could either be entering as a "valid" signal meaning that the audio from the TV has this buzz on it for some reason... either a fault or "just the way it is".
Or it could be something more complex. It's a process of elimination.
What you could also try... safe to do but be aware of excess noise level, is to disconnect both L and R phono leads and connect a pair of headphones (just hold the plug across the phone plugs to connect across any of the 3 connections on a h/phone socket) and that will give audio in one or both earphones depending how you connect but it should let you see if the buzz is there. TBH that might be the quickest way to see if the audio is "clean" from the TV.
Old 14th July 2011, 06:52 PM   #9
Mooly's Avatar
That should read h/phone plug above
Just confirm what you said before.
"The buzz is not there when volume is on minimum". Is that with or without leads connected.
Old 14th July 2011, 06:59 PM   #10
benb is offline benb  United States
Is the TV connected to a cable TV connection? If so, disconnect that and see if the hum stops. There's a simple RF isolation transformer you can add between the TV and the cable. I understand the cable TV connection is the cause of hum in many or most cases involving audio and TV's.
Hum through speakers using GC & Laptop zebra100 Chip Amps 22 23rd August 2011 01:39 PM
Hum in right speaker becomes hum in both speakers when headshell detached THX1979 Analogue Source 16 24th June 2011 08:59 AM
Powering two Speakers from one amplifier channel. ]|[ GorE Multi-Way 4 3rd July 2005 04:12 AM
Powering speakers over long distances? edave Everything Else 5 2nd April 2005 10:06 AM
Page generated in 0.12389 seconds (73.57% PHP - 26.43% MySQL) with 10 queries
