Hey guys. I've got a relatively silly question. I'm making a selector switch using a couple of 20 amp relays with 12vdc triggers. I plan on using the switch as a comparison switch between satellite speakers. I'm going to run the hpf output from my passive sub crossover into the common on the relay and use the NO and NC taps on the relays on the 2 different sets of sat speakers.
My question is, momentarily, my amplifier will be driving just subs, as the relay is break before make. Will rapidly switching which satellite speakers are connected (with a brief period of neither) have any ill effects on my amplifier? I plan on doing this at relatively low volume. I'm fairly sure that it will be ok, but I'd rather hear from an electronics expert before I toast my amplifier by suddenly shifting impedance around rapidly. Thanks fellas. |
#2 |
Break before make is fine. Make before break would be very expensive!
| Selector switch question | PWR RYD | Tubes / Valves | 3 | 13th January 2011 09:41 PM |
| stupid switch question | bigjppop | Tubes / Valves | 9 | 11th January 2010 06:49 AM |
| Tubelab build selector switch question | pforeman | Tubes / Valves | 2 | 28th October 2009 03:54 AM |
| Selector Switch Pop - Newbie Question | LHMAudio | Solid State | 5 | 18th May 2009 11:31 PM |
| A Selector Switch? | JohnnyBoy | Class D | 5 | 15th February 2006 03:33 PM |
| Page generated in 0.06914 seconds (69.59% PHP - 30.41% MySQL) with 10 queries |
