Hi all.
Just some evening fun. I thought why not try making a all mosfet amp? only the ccs if JFET based. It took 1 hour. First impression is good. The goal was only a few types of components.
Comments are welcome. Todo:
#2 |
Good.
Nice project for having a different Preamp. If you can find JFET which is more commonly available for the current sources, then this would be fine. U309 is almost impossible to find and buy. (Mouser, Farnell, DigiKey)
lineup |
#3 |
Very cool I know of a similar project that used +-200v supplies! jer
#4 |
J309 is identical and available. I have to find a solution for the bias generator - maybe something like LM431!?
#5 |
Mosfets are so noisy, you should really use Jfet inputs.
#6 |
with 11x gainthe noisefloor is 63nV.. That's okay for me.
#7 |
I didnt know zetex supplied noise figures for their mosfets, I must look it up.
Is this the result from LT Spice sim ??? Last edited by homemodder; 13th July 2011 at 02:31 PM. |
#8 | |
I'd tie the gates of J2/J4 to the source of J1/J3. Gives much better CCS output Z. Samuel |
#9 |
I would use ZVN3310 based Vgs multiplier.
Non é mai abbastanza... |
#10 |
Electrons are yellow and more is better!
My first thought also some years ago but notice that Mr. Pass is using them in high-end products.
/Per-Anders (my first name) or P-A as my friends call me |
| Simple opamp/mosfet shunt regulator | ikoflexer | Solid State | 64 | 12th March 2009 06:38 PM |
| Opamp/mosfet power amplifier | Dusk | Instruments and Amps | 4 | 27th March 2007 10:44 PM |
| Kunthrandum - OpAmp biased MOSFET amp | ronybc | Solid State | 6 | 10th August 2005 06:30 PM |
| mosfet and opamp amplifier | darkfenriz | Solid State | 32 | 15th July 2004 01:17 AM |
| Page generated in 0.12139 seconds (68.89% PHP - 31.11% MySQL) with 11 queries |
