diyAB Amp - The "Honey Badger"
Old 1st March 2013, 07:27 AM   #921
ostripper is offline ostripper  United States
ostripper's Avatar
Originally Posted by Stormrider View Post
Sorry if I missed it, but what does R9, R10, and R14 do in the LTP CCS do?
I have the boards!!
#1 - will fill the BOM from mouser , mouser has a "shared cart" option.
I must learn the mouser way to "share" my cart (XML format) , then all the
premium parts (ha ha) that I pick will be a click away.
#2 - Since I have 4 boards (really!! ... guys) I will make 2 "flavors" of the badger...
one bjt input and one FET!!! input.
#3 - having the actual boards ... I can source the best components (looks +
specs) from the best distributors. --- mouser , digikey , even ebay (noble 5W .22R 10mm LS emitter resistors).
R9-10 are base stoppers to end any high gain CCS oscillation. R14 is a Douglas Self addition (read the book).
These boards are BEAUTIFUL !! I will use 2 for parties , the other 2 will be "lab'ed" to show the ultimate scope of this universal AB amp. (6 different amps on one board) ... that is how I designed it !!
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 1st March 2013, 07:35 AM   #922
ostripper's Avatar
I have the boards!!
OS
Old 1st March 2013, 03:43 PM   #923
mattmcl is offline mattmcl  United States
Fantastic! That's what I've been waiting for too. Thanks for all your hard work ostripper.
Old 13th March 2013, 09:03 PM   #924
Lukky is offline Lukky  United States
Stuffing my boards right now and wanted to express a little frustration: Some of the holes are a *little* too small. I'm not sure what the hole sizes are, but...
R6 on one of my boards had to be reamed out. The lead diameter of my resistor is 0.64mm.
R43-R48 had to be reamed on both boards. My lead diameter: 1.02mm.
C8, C18, C19 - Mica caps are fairly limited on Mouser. I had to get 500V versions for these three: lead diameter of 0.8mm.
Maybe on the next board spin these could be opened up a little. This is slowing me down!
Old 18th March 2013, 06:36 PM   #925
Please don't take this as complaining, just trying to help make a better product.
On the back of the HB board there's solder mask covering C18 and C19. I scraped it off with a razor blade.
There's also mask over the "C-R-Z" jumpers in the cascode.
I didn't solder in any jumpers though, because there are already traces on the top layer.
...still a few days from firing it up. hopefully not in the literal sense.
Old 21st March 2013, 02:13 PM   #926
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by ostripper View Post
Since I have 4 boards (really!! ... guys) I will make 2 "flavors" of the badger...one bjt input and one FET!!! input.
Fet input? Oh, is this perchance, an integrated buffer, so that my laptop source can produce flat non-shout midband response and really rockin bass? Well, that performance does take a buffer and integrated would be really cool.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 31st March 2013, 04:46 AM   #927
Juvenal is offline Juvenal  United States
I ran into the same issue, except with almost all my resistors..
Luckily I have access to a chemical lab at work and was able to etch the leads on the resistors instead of drilling the boards, that sped up things greatly.
Old 28th April 2013, 07:38 AM   #928
marian adrian is offline marian adrian
hei and schematic amplifier please
Old 28th April 2013, 07:10 PM   #929
currentflow is offline currentflow  United Kingdom
Practically everything you require may be found in the store link here:
The diyAB "Honey Badger" Class AB Power Amp - 150W/Channel (2 Channels) - PCBs
currentflow
Old 3rd May 2013, 08:27 PM   #930
Art M is offline Art M  United States
Default Low voltage operation exception
"And don't put a resistor in the tail of the input stage pair "
" The notional function of the resistor in the tail was to minimize the damage if the tail current-source transistor failed short-circuit "
" The unwanted result was that these amplifiers would not work on very low rail voltages.... " Douglas Self
diyAB Amp - The "Honey Badger"Hide this!Advertise here!
diyAB Amp The "Honey Badger" build thread Variac Solid State 3058 14th June 2018 05:34 PM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 06:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
