diyAB Amp - The "Honey Badger"
Old 10th October 2012, 02:39 AM   #851
OnAudio is offline OnAudio
OnAudio's Avatar
Originally Posted by chunek View Post
Most of the transistors I can get quite match with same batch. The only problem is on the driver transistors pair MJE15032G and MJE15033G from Mouser. The first has hfe 100+ and the later having 160+. Is it a problem to use it here as the different is almost >50%?
You may just get away with it despite the introduced distortion. For well designed amplifiers that use negative feedback as a control measure you may just get away with it. Also note that these are on opposite sides of the swing .
Looking at the badger schematic, those are very sensitive transistors. It will sound so much better if matched.
onaudio.herokuapp.com
Old 10th October 2012, 11:26 AM   #852
chunek is offline chunek  Singapore
Thanks OnAudio for your advice! Could I know how much is in the acceptable range? Let's say in term of %! Is <10% considered good?
Old 10th October 2012, 04:24 PM   #853
OnAudio's Avatar
Thats correct <= 10%
Old 10th October 2012, 08:06 PM   #854
R.I.P.
I found that samples before and after the rohs change were very different.
I could get hFE matches with pre-rohs of pnp to post rohs NPN and vice versa. Or was it the other way around?
regards Andrew T.
Old 10th October 2012, 09:07 PM   #855
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
OStripper's favorite pair is NJW0281G and NJW1302G.
The HFE and FT graphs in the datasheets are similar.
The low priced devices, have high end specifications.
Cheers!
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 10th October 2012, 09:21 PM   #856
keantoken is offline keantoken  United States
keantoken's Avatar
I seem to recall that was back when those devices didn't come 10% matched from ONSemi.
However if you're really pushing a design, it may really help to have outputs with matched Ft/Cob behavior, so you can have a more consistent UGBW point under dynamic conditions.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 12th October 2012, 12:00 AM   #857
The output stage, I bought the recommended pairs NJW0281G and NJW1302G. I manage to get 6 pairs out of 12 pairs (hfe 114 vs 125 best match. Actually they are ~10% diff & quite matched with their spec )
For the driver stage, not that lucky!
Thanks all! I will try to look this matched pairs.
Old 14th October 2012, 07:20 AM   #858
Driver:
OStripper's recommended drivers:
MJE15032/MJE15033, OnSemi
MJE15030/MJE15031, OnSemi
MJE15028/MJE15029, OnSemi
2SC4793/2SA1837, Toshiba
Optional drivers may or may not include:
I do not know if these are suitable
2SC5171/2SA1930, Toshiba
2SC2362/2SA1016, Sanyo
2SC1815/2SA1015, Sanyo
2SC2240/2SA970, Toshiba
2SC2238/2SA968, Toshiba
*HFE measure for higher current editions of TO220 Drivers: The HFE needs to be measured in realistic operating conditions, warmed up, loaded slightly, and on. The digital multimeter's test port might not be quite enough workout and the operating temperature at room temp, might not be realistic. See the respective datasheet HFE graphs for more information on what divergence, if any, that you could expect at room temp.
**Recently, smaller OnSemi devices may or may not be China fab at a different plant, in which case the HFE of that part may be a LOT lower. As troublesome as that is, the problem gets worse when sourced from two different fab plants, pairing a good device with a plonker. If the datasheet does not indicate the HFE should be strongly divergent at room temp, then the remaining solution is to purchase from a different vendor.
Output:
NJW0281/NJW0302, OnSemi
NJL0281/NJL0302, OnSemi
MJW0281/MJW0302, OnSemi
MJL0281/MJL0302, OnSemi
NJW3281/NJW1302, OnSemi
NJL3281/NJL1302, OnSemi
MJW3281/MJW1302, OnSemi
MJL3281/MJL1302, OnSemi
2SC3281/2SA1302, Mospec
NJW0281/NJW1302, OnSemi
NJL0281/NJL1302, OnSemi
MJW0281/MJW1302, OnSemi
MJL0281/MJL1302, OnSemi
NJW21194/NJW21193, OnSemi
MJL21194/MJL21193, OnSemi
MJW21194/MJW21193, OnSemi
MJ21194/MJ21193, OnSemi
NJL4281/NJL4302, OnSemi
MJL4281/MJL4302, OnSemi
2SC5200/2SA1943, Toshiba
FJL4315/FJL4215, Fairchild
FJP5200/FJP1943, Fairchild
KSC5200/KSA1943, Fairchild
*Lower HFE outputs need to be triple paralleled for HB; however, high current high dissipation high HFE outputs may work in double-parallel config that may or may not be easier to match. See the respective datasheets for more relevant information.
Old 29th October 2012, 02:50 PM   #859
Rokhadin Nopianto is offline Rokhadin Nopianto
thank for all
Old 13th November 2012, 08:16 PM   #860
kclusa@yahoo.co is offline kclusa@yahoo.co  United States
Default Amp sound tuning
Hi Everyone,
I was wondering whether anyone tuned this amp ?
Can you share the experience and procedure with me please ?
Just got the PBC, collecting the parts and currently soldering everything together.
However, the capacitor selection started with WIMA cap ?
My understanding of Amp building is started the most natural sound without any high end cap. This will give the most smooth response to begin with.
If you start with high end cap, a unique sound signature already build in and will be hard to find other cap to cancel this effect plus adding the new sound signature as you desired.
Lou
diyAB Amp - The &quot;Honey Badger&quot;Hide this!Advertise here!
diyAB Amp The "Honey Badger" build thread Variac Solid State 3033 13th April 2018 02:43 AM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 06:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
