#841 |
Can some one who has boards check to see if mica caps (47pF) will fit in positions C18 and C19. The lead spacing on the PCB diagram looks small to me. Can ceramics be used in this position if there is not enough room?
Also C5 on the BOM says lead spacing 3.5mm but I think the PCB is 2.5mm. |
#842 |
#843 |
Just got the 2 boards and they look great. I've been through the build guide and searched this tread to find out what the C R Z link is on the board? I may have missed it but can you point me to the right spot for some info. Thanks.
#844 |
read build guide on sub topic of ideas and alternatives
#845 |
Found it, thanks naf!
#846 |
What do you think of this?
Virtural Dual Mono adaptation Power board looks like: Bridge-Rectifier, 3,300uF, PI-Resistor, 10,000uF, 0.1uF Bridge-Rectifier, 3,300uF, PI-Resistor, 10,000uF, 0.1uF Output end of power board has 2 of 16A Schottky or Fast Silicon for V+ Output end of power board has 2 of 16A Schottky or Fast Silicon for V- V+ diodes at output point at amp board. There's 1 for left and 1 for right. V- diodes at output point at power board. There's 1 for left and 1 for right. Adding a pair of Cornell LP 2,200uF (high efficiency signal grade) very nearby the left channel amp board, And another pair of Cornell LP 2,200uF very nearby the right channel amp board. Left speaker return cable is centerpoint of the 2,200uF caps at the left channel amp board. Right speaker return cable is centerpoint of the 2,200uF caps at the right channel amp board. Input system is with 4 pole rotary for source selector, insulated RCA jacks, and 4 conductor cable (2 conductors for left input, 2 conductors for right input). There's Dual Mono, 2 individualized channels, only 1 transformer to buy?
♦ Tools & Guides ♦ ClipNipper headroom boost ♦ Parallel LM1875 pt2pt ♦ Easy parallel TDA7293 board ♦ TDA7294 pt2pt ♦ My post has opinion. |
#847 |
I would not do that.
What's a Pi resistor? Why two schottky after the caps? Why more diodes at amp board? Why cornell caps between PSU and amplifier? Why speaker return connected to a dirty ground? Why dual wiring of the interconnections? Why one transformer for a dual mono arrangement? |
#848 |
It refers to the R in a CRC power supply. That is not directly related to virtual dual mono. Why two schottky after the caps? Power board has individualized left channel and right channel power outputs for both V+ and V-. I count a total of 4 diodes added as the output of the power supply board. diode V+ for left channel diode V+ for right channel diode V- for left channel diode V- for right channel This is the left, right splitter, diode isolated, that accomplishes the stereo separation of virtual dual mono. It is less expensive and less complicated than individualized regulators/capmulti per left and right for virtual dual mono. Why more diodes at amp board? There's no extra diodes added to the amp board. Why cornell caps between PSU and amplifier? Pairs of high efficiency 2,200uF caps added to both amplifier boards. It is to stiffen the rails individually per left and right channels. It is unnecessary to add these caps. Why speaker return connected to a dirty ground? This particular virtual dual mono scheme works well with ordinary/orthodox star grounding. Why dual wiring of the interconnections? The V+, 0v, V- do "Y" per Left channel amplifier and Right channel amplifier at the output of the earthed power supply board. With the power board's 0v earth grounded, that is the location of central star ground. This implies simple ordinary 3 conductor power interconnect cables for each amplifier board. Individual left channel and right channel cables is because of dual mono. Why one transformer for a dual mono arrangement? That is because of transformer costs.
♦ Tools & Guides ♦ ClipNipper headroom boost ♦ Parallel LM1875 pt2pt ♦ Easy parallel TDA7293 board ♦ TDA7294 pt2pt ♦ My post has opinion. Last edited by danielwritesbac; 16th August 2012 at 10:41 AM. |
#849 |
Hai all
#850 |
Hi all, I am new at the forum.Watching this thread I wonder about the specifications of this amp. Only given the sup.voltage, but never read about THD or risetime or
F u to Fo etc. Can one help me ? thanks all Ingo at the center of Berlin |
| diyAB Amp The "Honey Badger" build thread | Variac | Solid State | 309 | Yesterday 03:10 PM |
| Honey, I smoked the Weller 8200 | jackinnj | Equipment & Tools | 5 | 25th April 2011 06:07 AM |
| Badger Badger Badger..... Mushroom !! | 5th element | Everything Else | 15 | 20th September 2003 03:16 PM |
