Old 23rd June 2012, 11:23 AM   #821
AndrewT is online now AndrewT  Scotland
I would not recommend 340/350 as substitutes for 1381/3503
The only parameter they have in common is 300Vceo.
D1 & D2 are not 1n914 @ 1A as stated in the BOM. These should preferably be rectifier diodes, 1n4001 or similar.
1n914 are signal diodes.
Old 23rd June 2012, 12:04 PM   #822
Harry3 is offline Harry3  Australia
Andrew thanks.
If I build this amp I would use 500VA transformers for each channel and large heat sinks. So the power supply should not be an issue. I would like the amp to be able to drive 4ohm or less drivers and hence my question of using 4 pairs on the output.
Old 23rd June 2012, 12:16 PM   #823
JojoD818's Avatar
Originally Posted by naf View Post
Would it still good performance if i build HB using mje340/350 instead of ksc3503/ksa1381?
The other prototype uses mje340/350 types, no problem at all.
Unless you have a built in scope in your ears.
Old 23rd June 2012, 12:36 PM   #824
naf is offline naf  Indonesia
Thankyou very much Sir, yes i see clearly picture of VBe prototype using mje and i think big vavas and ccs using this too. I will build using toshiba TR for driver and final.
Old 23rd June 2012, 12:43 PM   #825
JojoD818's Avatar
Just remember to be careful sourcing those toshiba for I read reports of counterfeit toshiba parts.
Old 23rd June 2012, 02:04 PM   #826
Sir, Thank you very much for your attention. I'll carefully sourcing those toshiba TR.
Old 23rd June 2012, 02:43 PM   #827
jofual is offline jofual  Indonesia
Hiii all...
Can any body tell me about the sound quality of this amplifier.. ? I plan to built the stereo amp that have very good in sound..
can we compare with the Sr 200..? wich is the better sound? thanks..
Old 23rd June 2012, 02:56 PM   #828
@jofual: All i know, ostripper designer of this amp. Put all the best of his expreince to this amp. I'm not built it yet. But i bet this is a very good amp. Try to read thread of frugalamp and mongrel and you know who was ostripper. I've built sysmasym v5.3 and this amp derived from. Ostripper supersym ii aka mongrel. if you want to build it i think we can share expreince in our local forum
Old 2nd July 2012, 06:59 AM   #829
blakkshepeaudio's Avatar
Any news on the parts pack?
Old 4th July 2012, 03:09 PM   #830
danielwritesbac's Avatar
Default Operating voltage. . . can I use less than 60v rails?
Hey, I was wondering if I could use 35vdc rails in case I happened to have 2 way speakers and didn't need to crack up the vocals coming from the madly shaking woofer (aka didn't quite need the 150 watts when 60 would do) or in case I have 4 ohm speakers that need good current but didn't quite need as much voltage, then could I use 42vdc rails?
I guess I just need a briefing on what rail voltages work well for this amp. Is it specific to 60vdc rails or can I use less without getting into a lot of modifications?
Thanks!!
Tools & GuidesClipNipper headroom boostParallel LM1875 pt2ptEasy parallel TDA7293 boardTDA7294 pt2pt ♦ My post has opinion.
diyAB Amp The "Honey Badger" build thread Variac Solid State 309 20th May 2013 03:10 PM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 06:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
Copyright ©1999-2013 diyAudio
