Old 23rd June 2012, 12:09 AM   #811
JojoD818's Avatar
Who is JP?
Oh sorry did I say "high"? I thought I said "high side".
But thanks for summing that all up.
Old 23rd June 2012, 06:49 AM   #812
Harry3 is offline Harry3  Australia
Guys thanks for the replies.
I just want to clarify - can I add an extra output transistor using 60V rails to easily drive 4 ohm loads? If yes what modifications? Thanks.
Old 23rd June 2012, 07:29 AM   #813
JojoD818's Avatar
There are already 3 pairs of output transistors, are you asking for a 4th pair?
Old 23rd June 2012, 07:38 AM   #814
Yes I would like to use 4 pairs - for 4ohm or less loads.
Old 23rd June 2012, 07:53 AM   #815
JojoD818's Avatar
With a substantial amount of heatsink, the original 3 pair output can already drive 4 ohms loads with gusto as long as your psu can also handle it. I did try it for home hifi only though, not for a party rig. It also used the recommended output transistors, I did not upgrade to the big ones.
Old 23rd June 2012, 08:10 AM   #816
Re-reading Andrew's post 751 - he was refering to two pairs of output transistors, only being able to drive 6 ohms. So I assume 3 pair would be enough for 4 ohms. However I would prefer to have 4 pairs on the ouput.
Old 23rd June 2012, 10:16 AM   #817
Yes, I was referring to a 2pair output stage using those transformer voltages.
The actual load capability will depend on how you build the amplifier and how hot you run it and what PSU you use and what your view on reliability vs de-rated SOAR you have.
Personally, I would carry out a modeling of the amplifier PSU+Output stage & Driver stage to assess what it's load capability could be. That is beyond many Members here, so I posted a quick and easy guide.
Old 23rd June 2012, 10:42 AM   #818
naf is offline naf  Indonesia
Would it still good performance if i build HB using mje340/350 instead of ksc3503/ksa1381?
Old 23rd June 2012, 10:44 AM   #819
If you don't know, then don't modify.
Old 23rd June 2012, 10:56 AM   #820
Sir, i.m not modify it. I read on build guide there is alternative for 3503/1381.
If still good using 340/350 i would like to build, if don't i'll try another
diyAB Amp The "Honey Badger" build thread Variac Solid State 326 12th June 2013 10:03 PM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 06:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
