diyAB Amp - The "Honey Badger"
Old 22nd June 2012, 12:59 PM   #801
R.I.P.
I gave some advice in post751.
regards Andrew T.
Old 22nd June 2012, 03:16 PM   #802
Krisfr is offline Krisfr  United States
Krisfr's Avatar
Originally Posted by Stormrider View Post
Right, this is a basic dual emitter follower design. Lower impedance speakers will put a higher load on the VAS than a triple EF output stage would. Simply adding more output transistors would help, but even at +/-70Vdc the VAS will be pushed harder than intended.
The amp was designed around +/-60Vdc rails. Unless you can do the calculations, and modify the design properly yourself, you should build it as the designer intended.
Is there anyone that wants to re-do this design for higher voltage rails and more output devices? Is it even possible?
Also would this design be better with separate front end power supplies?
Never give a Systems Analyst a screwdriver or hammer
Old 22nd June 2012, 03:29 PM   #803
Rob_S is offline Rob_S  United Kingdom
Thanks both for the replies. Shame there is not a simple tweak for this.
as I have a 45v AC, 1kva may have a look for a different project :-)
Old 22nd June 2012, 03:59 PM   #804
Stormrider is offline Stormrider  United States
Stormrider's Avatar
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
45vac x sqrt2 =~ +/-63Vdc. This would be ok for 6-8 ohm speakers assuming a constant mains voltage, and the transformer is of high quality with good regulation.
AJ
Old 22nd June 2012, 04:18 PM   #805
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Please see my post re the prototype of the HB amp. It uses 45VAC toroidal too.
Originally Posted by JojoD818 View Post
The HB prototype currently drives a pair of 6 ohms Wharfdale 9.1 speakers, but it also drove a pair of 4 ohms Dynaudio Audience for about 2 days too. Aside from that, it has driven other bookshelves and floorstanders of different brands.
The secondary of the toroidal I used in the prototype is 45VAC.
So far the amp is still alive.
Old 22nd June 2012, 04:20 PM   #806
will be closer to +/-68vdc, just checked its a 230v AC to 45v AC, my mains is currently 246.8v AC. So would be pushing as I don't want to be restricted on speakers.
Thanks for the feedback :-)
Thanks JojoD818 will take a look (saw your post a little on the late side :-) )
Old 22nd June 2012, 04:24 PM   #807
JojoD818's Avatar
It seems your mains are on the high side, are they like that for the whole day?
You're welcome, you may also find the downloadable official build guide at the store.
Old 22nd June 2012, 05:50 PM   #808
R.I.P.
JP,
our UK mains supply is still a nominal 240Vac +-6% although for the sake of Harmonisation it is specified as 216Vac to 254Vac.
246.8Vac is only 2.83% above nominal voltage. That is NOT high. That is well within the specified range and well within the "normal UK" voltage.
regards Andrew T.
Old 23rd June 2012, 12:09 AM   #809
JojoD818's Avatar
Who is JP?
Oh sorry did I say "high"? I thought I said "high side".
But thanks for summing that all up.
Old 23rd June 2012, 06:49 AM   #810
Harry3 is offline Harry3  Australia
Guys thanks for the replies.
I just want to clarify - can I add an extra output transistor using 60V rails to easily drive 4 ohm loads? If yes what modifications? Thanks.
diyAB Amp - The "Honey Badger"Hide this!Advertise here!
diyAB Amp The "Honey Badger" build thread Variac Solid State 3058 14th June 2018 05:34 PM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 06:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
