| Thread Tools | Search this Thread |
#551 |
diyAudio Editor
Alex, Need your e-mail, the one on file bounces. I have a nice packet made up for you to review..
Thanks, MArk |
#552 | |
AJ |
#553 |
diyAudio Editor
I meant to say "big output devices!"
#554 |
This looks very appealing for first time amp build - thanks to OStripper for his efforts in starting this, and for Variac and others for keeping the work going.
I worked for Arcam as undergraduate 20 years ago (test and repair of Delta60/90/120 amps)...and this looks an ideal project to recapture some youth ;-) In prep for the boards availability, can anyone point me in direction of practical chassis/heatsink combination that would suit this project. |
#555 |
This will be the power supply for our prototype. It consist of 3 sections namely Cap/Diode/ and Soft Start section. I made a couple for a dual cap/diode configuration so there will be a separate filter and rectifier boards for each channel.
Abacus Robot CNC - YouTube Posted this also in the tool section. |
#556 |
diyAudio Editor
I just received an e-mail from Alex. He confirmed that the active devices are where they should be and the mounting holes will work fine. We'll be sending it out for boards in the next couple of days, and it should be in the store in 6 weeks about.
Thank you Alex for your helpfulness.. Mark
Burning Amp Festival Sunday, October 28th, 2012 in S.F. We need Volunteers & sign-up's for what you're bringing! Last edited by Variac; 15th February 2012 at 01:13 AM. |
#557 |
Mark,
Which will be the specs for the board? FR4 Double sided silkscreened....? |
#558 | |
#559 |
Hey guys, I won the quiz.
http://www.diyaudio.com/forums/power...ml#post2912276 I was thinking, if possible, I wanted to get some boards for this amp when it was finished. But I had the thought I might go instead for the Pass F5 boards. Any thoughts on what's the difference, subjectively?
Contribute to the DIYAudio WIKI! http://www.diyaudio.com/forums/every...p-sign-up.html LTSpice wiki with special attention to new users' troubles |
#560 |
The F5 is a very nice amp and will work well with most all 8 ohms speakers but is only 25 watts, it drives my 3 ways with 15" woof which is around 89/90 dB/watt but it lacks a bit of authority on a big room, and this is why I'm looking to this Ostripper creation besides being a bjt since all my other solid state amps have been FET.
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| gasgall |
| diyAB Amp The "Honey Badger" build thread | Variac | Solid State | 9 | 22nd May 2012 04:13 AM |
| Honey, I smoked the Weller 8200 | jackinnj | Equipment & Tools | 5 | 25th April 2011 06:07 AM |
| Badger Badger Badger..... Mushroom !! | 5th element | Everything Else | 15 | 20th September 2003 03:16 PM |
| Page generated in 0.10124 seconds (74.34% PHP - 25.66% MySQL) with 11 queries |
