diyAB Amp - The "Honey Badger"
Old 7th February 2012, 07:18 PM   #521
alex mm is offline alex mm  Romania
alex mm's Avatar
Default PCB REV 1.8
...... I layout this rev 1.8 and ask you what's wrong with PCB ? Size only 190 mm X 88 mm . I can also modify OS PCB for us in better shape ......
Alex.
Old 7th February 2012, 07:55 PM   #522
Stormrider is offline Stormrider  United States
Stormrider's Avatar
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
Alex, that PCB looks good, but the diyAudio PCB needs to work with heatsinks already drilled for a different project to meet the goals set forth at the beginning.
It stinks OS is unable to give his final sign of approval on the board, but he has been inactive since 10/2011. I agree it is time to move on, especially since the PCB design seems to be complete except for some small details.
AJ
Old 7th February 2012, 08:06 PM   #523
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Alex.
Nice PCB Alex, way to go!
Old 7th February 2012, 09:34 PM   #524
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Alex.
nice layout, users of Conrad Engineering hatsinks will find this layout very useful...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 7th February 2012, 10:33 PM   #525
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
+1. We will move forward ASAP on getting the boards - That I promise..
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 9th February 2012, 12:42 AM   #526
Woody1911a1 is offline Woody1911a1  United States
Alex.
love that alex mm is here for us . his pcb design work just amazes me !!!! however i do question all the heat from the outputs so tightly together .
cheers Woody
Old 9th February 2012, 01:17 AM   #527
TonyTecson's Avatar
imho, having those power trannies close together means they will track each other better, not a bad thing......especially when using conrad engineering heatsinks....
Conrad Heatsinks - Products
Old 9th February 2012, 04:47 AM   #528
keantoken is online now keantoken  United States
keantoken's Avatar
Alex, the decision to put the rails both on one side of the board, instead of wrapping around it was made for a reason. Furthermore, the feedback point is at not at the output terminal where it should be. OS's board was very carefully designed. Do not underestimate OS's work.
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 9th February 2012, 11:13 AM   #529
R.I.P.
Do not redesign the Ost PCB.
Variac, don't dare say a word !
regards Andrew T.
Old 9th February 2012, 01:01 PM   #530
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
diyAB Amp - The "Honey Badger" Send a message via MSN to AKN
Hi Andrew,
I remember that it was you who influenced OS to put the rails together. IMO a wise decision. If one wonder, just look back in the thread.
My
The layout could perhaps be even better while keeping the OS style layout. If we look at the PS section, loop area could be smaller. The cap closest to output section could feed BJT's furthest away and vise verse...
/ Anders
diyAB Amp - The "Honey Badger"Hide this!Advertise here!
diyAB Amp The "Honey Badger" build thread Variac Solid State 3051 15th May 2018 03:45 AM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 06:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
