#511 |
Yes... from post 188?
#512 |
#513 |
Just checked this and no it wasn`t from post #188, this file doesn`t include Gerber`s at all.
Must have been from OS`s website (later) .
Christoph STEAL the BEST - INVENT the REST |
#514 |
See, knew I missed something.
I've loaded up the files and from what I can see the distances between the output devices (c-c) are all 40mm (that's what people worried about if I understand correct). Hard to measure with any insane accuracy since there's no snap function or anything. Anything else that needs measuring? Will do more tomorrow afternoon, now I need sleep. |
#515 |
diyAudio Editor
PM sent to Mjjg. Please don't post links to possible Gerber's here. We need to work with the latest files , and we'd also prefer not to have these show up on e-bay after we've invested in hiring ostripper. Especially since the potential e-bay versions may be the wrong version. But, in exchange, we'll stop hoping for os to respond, and move forward on the small corrections needed, or if that doesn't work out, send them out as they are, as its mostly the mounting holes that are the problem..
Once the boards are in production, and some built, we'll post the Gerbers Mark
2013 Burning Amp Festival announced: Sunday, October 6th in S.F. We need Volunteers & sign-up's for what you're bringing! Last edited by Variac; 6th February 2012 at 08:07 PM. |
#516 |
........ I can generate Gerber's for OS PCB just let me know .
I cant let you down diy guys It was first step .......Alex. |
#517 | |
or did You work on this already before?
#518 | |
If my post was not clear.... I do agree that any new pcb layout has to follow OS's layout as close as possible - only deviating to accomodate the diyAudio mounting standard. Any and all credit should also stay with OS. |
#519 |
diyAudio Editor
I think that Alex worked with ostrippper to create the first version. Maybe the best thing is to send the latest version to Alex and he (and I ) check for changes and update the board. Then he can move the holes around as we wish, and we're good to go!!
#520 |
Os version that I made was shown in post 170.
http://www.diyaudio.com/forums/solid...ml#post2648822 There was nothing wrong with the layout that OS produced. It works, and quite well I must say. Maybe it could have been a little more compact as it is fairly large, but that is all. Regards Simon |
| diyAB Amp The "Honey Badger" build thread | Variac | Solid State | 307 | Yesterday 10:07 PM |
| Honey, I smoked the Weller 8200 | jackinnj | Equipment & Tools | 5 | 25th April 2011 06:07 AM |
| Badger Badger Badger..... Mushroom !! | 5th element | Everything Else | 15 | 20th September 2003 03:16 PM |
