diyAB Amp - The "Honey Badger" - Page 38 - diyAudio
Old 6th November 2011, 03:24 AM   #371
Originally Posted by JojoD818 View Post
I have used the same in my more than 8 year old diy amp and so far I see no problem. The cable tie I used is somewhat stretchable and not that brittle.
I'd welcome it very much if you have a better technique to share.
Yes, as mlloyd1 pointed out, I would expect heat shrink to work quite well. Superior to cable ties? Perhaps not significantly so.
Old 6th November 2011, 01:47 PM   #372
JojoD818's Avatar
Originally Posted by Tony View Post
you can also use this "panduit" stainless steel ty-wraps.......Stainless Steel Cable Ties, Permanent Identification
Thanks tony, those things looks real sturdy...
Originally Posted by mlloyd1 View Post
heat shrink tubing also works well here for small signal devices
mlloyd1
thanks, that's a great idea and should really work well too..
I'd stick with the cable ties for now, will try the heat shrink tubes in another project though...
Old 6th November 2011, 03:32 PM   #373
JojoD818's Avatar
got some diy on a Sunday morning...
Old 7th November 2011, 05:04 AM   #374
JojoD818's Avatar
Torn between these two... big brother or baby brother?
I need a drink...
Old 7th November 2011, 06:07 AM   #375
Big Brother
Old 7th November 2011, 09:19 AM   #376
JojoD818's Avatar
Originally Posted by jacobthellamer View Post
Big Brother
There's one vote, anybody else?
I actually have both sets of the MJW and the MJL... I'm just looking for enough reason to use the bigger ones I guess...
Old 7th November 2011, 09:25 AM   #377
If you are using multiple pairs then the little brother may give adequate cooling/dissipation.
If you are using big brother than a one pair output stage is more feasible.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 7th November 2011, 09:25 AM   #378
JojoD818's Avatar
Baby steps... It's a holiday today so I got some time to work on the boards...
and some bokeh shots...
Old 7th November 2011, 09:26 AM   #379
Why does the Forum still allow remote server locations for automatically downloaded pics?
regards Andrew T.
Old 7th November 2011, 09:29 AM   #380
JojoD818's Avatar
Excellent point, I might just be wasting Big Brother for this amp if 3 pairs of Baby Brother is more than enough...
That's one point each for Big Brother and Baby Brother then...
diyAB Amp The "Honey Badger" build thread Variac Solid State 2637 22nd March 2017 08:09 AM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 06:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
Copyright 1999-2017 diyAudio
