diyAB Amp - The "Honey Badger"
Old 28th October 2011, 08:40 AM   #341
Ian Finch is offline Ian Finch  Australia
http://www.diyaudio.com/forums/attac...a-amp-full.zip
Sorry for errors, that's Q14.15 and now MJE15032/3 though either pair would suit
Ian
Old 28th October 2011, 10:24 AM   #342
niss_man is offline niss_man  Australia
Q13 I used 2sc3953 transistor as Q13. Thats the transistor in the middle of the heatsink used for temperature compensation I think. I used MJE15032/3 for drivers Q14/15 and the MJE15033(Q15) are the ones that blew as well as some power transistors. I am having the feeling that some of the transistors I bought may have been fake.
Repeet I think I will take you up on your offer. It would be nice to meet a fellow diyer in my same town.
PM sent Repeet
Simon
Old 28th October 2011, 03:08 PM   #343
odysseybmx414 is offline odysseybmx414  United States
Originally Posted by niss_man View Post
Have tested power supply without being connected to amplifier board and I get +ve and -ve 61v rails and bulb is not on. (ok)
When connected to amplifier boards +/-ve 50vdc and bulb is on very very slightly(hardly glowing)?
Theres some issue with my amplifier board somewhere.
What is the best place to start now? Maybe remove the power transistors and driver transistors and see if input bumps back up to 60v?
Edit Just found a shorted Q15 driver transistor.
Another question. Is it ok to use a 2sc3953 transistor as Q13??
Simon
If driver is shorted I'd guess outputs blown. Replace all outputs and drivers. Use complimentary devices don't mix n match. In the meantime after you've put all new devices in you can then test the old ones hfe etc to determine which are ok and which are not.
It is normal for unloaded trafo voltage to be higher than loaded voltage but ten volts is too much.
Old 28th October 2011, 03:32 PM   #344
discrete is offline discrete  Canada
...also use a lower wattage lamp initially for the lamp tester, e.g. 40 W, to get more than a 'hardly glow'.
(The voltage drop will be even more than 10 V with the lower wattage lamp, but that is the idea).
Old 29th October 2011, 11:59 PM   #345
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
diyAudio Central, in the person of JojoD818 has made an etched pair of boards and will do a test build. When he confirms that it works well, we'll get on with the order. After sending in the order it takes about 6 weeks to get in the store.
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 30th October 2011, 03:19 PM   #346
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
I've checked the board against the schematic and all seems where they should be, unless something slipped my tired eyes.
Anyway, like Variac said, I've started making preparations for a test build of this amp. Will post pics of the board soon... Drilling holes tomorrow, most part I hate when doing PCBs...
Old 31st October 2011, 09:11 AM   #347
JojoD818's Avatar
Progress from diyAudio Central...
Next is the daunting task of drilling them holes...
Old 31st October 2011, 10:52 AM   #348
Let's hope you don't get the same failure I experienced after putting one of these together jojo.
Simon
Old 1st November 2011, 02:07 AM   #349
JojoD818's Avatar
Simon
I hope so too. Are you rebuilding yours?
Old 1st November 2011, 05:03 AM   #350
JojoD818's Avatar
Happy Halloween everyone!
diyAB Amp - The "Honey Badger"Hide this!Advertise here!
diyAB Amp The "Honey Badger" build thread Variac Solid State 2950 5th December 2017 05:43 PM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 07:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 04:16 PM
Copyright ©1999-2017 diyAudio
