diyAB Amp - The "Honey Badger" - Page 29 - diyAudio
Old 19th September 2011, 11:09 PM   #281
Late edit:
Originally Posted by 454Casull View Post
So to recap yet again:
C2/C3 - please add one more hole to allow for 5.0 mm LS.
C5/C9 - I suggest that an 8.0 mm diameter cap will work, after checking with a vernier on a scale printout. Also, it seems like 6.3D/2.5LS is a more common size than 6.0 or 6.3/3.5 LS - do you agree?
C13/C17 - please add an extra pair of holes to allow for 10.0 mm LS.
Also,
C20 - please add 2 more holes to allow for 15.0 mm, 20.0 mm LS (required for polypro caps)... unless polypro caps offer no advantages vs polyester caps in this application.
C12/C16 - if you can move C11/C15 to the right a little bit, please do; a 5mm-thick cap (MKP/MFP) will be a tight squeeze here.
C10/C14/C21 - can you add a little more space between these caps? 5mm-thick (MKP/MFP) caps will not fit here... you might have to move R32 and C11 to allow that, though.
C6 - MKP box caps won't fit here, only polyester. Is this OK? There are 4.0mm-thick 0.1uF MKP caps available but even 4.0mm may be a very tight squeeze against the nearby transistor leg and resistor body.
C7/C8 - Cap ESL matters? C0G/NP0 usable here?
Old 20th September 2011, 01:24 AM   #282
ostripper's Avatar
Late edit:
All cap suggestions were implemented except the film caps .
2.5 to 4mm is common for .1uf /100v poly units. 250@.1uf is 5mm ....
http://www.vishay.com/docs/26009/mkt1818.pdf
Wima is similar "poly wise".
C7 and 8 are silver mica. Critical dominant pole(s) of the amp. I would not use poly's or ceramic for these. These pads are 7.5-10mm (C8 -430-470p) and 7.5mm for (C7-100p) perfect for 500v CDE silver mica's (my existing amp).
Worst case , if a certain size poly might not be available .... flexible leaded units can be used. http://www.vishay.com/docs/28132/mkt368.pdf
This would not be the case in most area's , as the vishay/wima's are very common and standardized.
PS-below is the "2.2" , same as 2.1 with a couple tweaks.
also , C5,9 ARE 2.5mm LS electro's .
Nice to be "alive" again , C2C. Tennessee was nice to me for a decade .
OS
Amps: http://www.fidelityforce.com/ostripper
Quad core Athlon - Asus essence sound (PCM 1792A) - Slewmaster "Spooky Leach" 200W amp (final favorite).
Old 20th September 2011, 02:17 AM   #283
Yeah, these are polyesters though. MKPs are much bigger, though if the extra quality isn't needed then I cede the point.
I didn't check that one so I didn't notice. Your BOM had them at 3.5.
Anyway, I'll look at it again with a ruler in a bit, thanks.
Old 20th September 2011, 02:22 AM   #284
49 - for the 19th time!!!
c2cthomas's Avatar
OS
Hey OS - it's great that you are "alive" - in all respects.
I'm transplanted here to Tennessee (my wife is a Nashville gal). I'm actually an Air Force brat that's traveled around and raised primarily in Texas and California.
I have a mess of my northern clan living in Johnstown N.Y. so you really can't get away from us!!!
Johnstown (city), New York - Wikipedia, the free encyclopedia
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 20th September 2011, 02:48 AM   #285
2SA1381 is the only difficult one; also, 2SC3503 is available, but not in huge quantities.
Mouser:
KSA1381ESTU Fairchild Semiconductor Bipolar Small Signal
2SC3503FSTU Fairchild Semiconductor Bipolar Power
Old 20th September 2011, 03:31 AM   #286
ostripper's Avatar
In reply to the TO-126 sourcing (1381/3503) , I have even built this type amp with the MJE340/350 VAS. The only difference is a little more overcompensation , lower slew , a little less open loop gain. Audibly , I was unable to differentiate the MJE's from the 1381/3503's.
Another sub would be the 2sa/c (ksa/c) 1220A/2690A. At 50v rails ,still has a 50% derated Vceo (160v). I will include more "less than ideal" but adequate semi's in my updated BOM.
OS
Old 20th September 2011, 04:59 AM   #287
In place of A1381/C3503 you could also use A1538, A1539/C3953, C3954. Perhaps, easy to obtain and nearly as good. I have used these and experienced a very audible difference compated to MJE340/350.
Sam
Old 20th September 2011, 01:29 PM   #288
Q1,Q2 -- MPSA18/SS9014 -- MPSA18RLRAG is available at Digikey
Q10 -- 2SA1381 -- not available at Digikey, Mouser; Newark recommends MJE350G
Q11,Q12,Q13 -- 2SC3503 -- not available at Digikey; 2SC3503FSTU available at Mouser (scheduled to become obsolete)
Q14 -- MJE15032 -- MJE15032G is available at Digikey
Q15 -- MJE15033 -- MJE15033G is available at Digikey
Q16,Q17,Q18 -- MJL3281 -- MJL3281AG available at Digikey
Q19,Q20,Q21 -- MJL1302 -- MJL1302AG available at Digikey (low quantities) and Mouser
Q3,Q4,Q7,Q8 -- KSC1845 -- KSC1845 (various types) available at Mouser
Q5,Q6,Q9 -- KSA992 -- KSA992 (various types) available at Mouser
2SA1381 and 2SC3503 -->> KSA1381 and KSC3503
Old 20th September 2011, 05:21 PM   #289
http://www.murata.com/products/catalog/pdf/c49e.pdf - page 45
http://www.epcos.com/inf/20/20/db/fc...MKT_B32232.pdf - page 8
The impedance vs frequency charts above... the C0G/NP0 caps have impedance minima at higher frequencies than the MKTs, but the MKTs (for some strange reason) show slightly lower impedance leading up to the impedance minima.
Old 21st September 2011, 02:08 AM   #290
Default Question for OS
Hi OS,
Good to see you back!
I did my own layout to suit components/heat-sinks/case materials on hand - hope you do not mind....
The heat-sinks are 12"x3"x1.5" flat backs, same height as my PCB, so the TO-3P packages end up close to the top/bottom edges of the heat-sink.
Power supply will be 40+40 VDC.
Based on your experience, do you think I will have thermal stability issues due to the placement of the drivers/Q13?
diyAB Amp The "Honey Badger" build thread Variac Solid State 2401 18th January 2017 10:35 AM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 07:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 04:16 PM
Copyright 1999-2017 diyAudio
