#141 | |
I will try to refine C1's layout , regardless. T93YB - T93YB 25K 10% datasheet No problem. OS
Mongrel website , always current and updated : http://www.fidelityforce.com/ostripper |
#142 | |
Universal large input cap trace w/jumper. Fixed ! Staggered 3 pin 2.5mm lead spacing / or inline 2.5mm trimmer pads. Fixed ! Broader sourcing is a asset for this project. ![]() OS
#143 |
Yes , 22mv between these TP's would give you 50mA per OP device. You could probe between either TP 1/2 and the "OV tp" for 11mv , as well.
OS
#144 |
#145 |
Stock TO-3p Sanken OEM = 8-9mv Re
What I run = 10mv Re (.22R) Sound is golden - no issue. Self was using old devices in his book. Vbias control is there to allow for whatever the preference is. If they have a large heatsink - run at 100+ ma , whatever they like. OS
#146 |
I am old , only have one set of eyes , no one in my house or neighborhood could possibly help (they know not what they see
)So , please look over this color draft of the project. RED = +60V /positive rail BLUE= - 60V /negative rail GREEN = earth and signal ground YELLOW = (dark yellow) - output trace / NFB orange = positive OP stage drive light blue = negative OP stage drive pink = non-inverted small signal path to VAS Reprinted , all devices have ample "real estate" (clearance) , all power semi's can be easily accessed with a screwdriver. Screenprint will show sections of circuit (LTP , cascode/CM , VAS, Vbe) for curious new builders .For convenience , the final schematic is also below. OS
Mongrel website , always current and updated : http://www.fidelityforce.com/ostripper Last edited by ostripper; 22nd July 2011 at 09:43 PM. |
#147 |
Sorry, maybe I missed something: there is a zener diode mark in schema (D3, near R18), that my eyes can't get to see. Please, help.
All the best, Max.
#148 | |
section of the "Options" text. ![]() wish I was 21 .. sheesh !OS
#149 |
#150 | |
![]() It makes a long time I wish to do this, but it seems there´s never "a final schematic"!! ![]() (sorry for this last statement, but I am no researcher or developer... I could only build it "as is", and evaluate the sonics and overall performance.)
All the best, Max.
| diyAB Amp The "Honey Badger" build thread | Variac | Solid State | 309 | 20th May 2013 03:10 PM |
| Honey, I smoked the Weller 8200 | jackinnj | Equipment & Tools | 5 | 25th April 2011 06:07 AM |
| Badger Badger Badger..... Mushroom !! | 5th element | Everything Else | 15 | 20th September 2003 03:16 PM |
