diyAB Amp - The "Honey Badger"
Old 2nd July 2014, 01:29 PM   #1271
R.I.P.
Janusz,
post1267 .doc
where is the schematic that shows the components coding/numbers?
regards Andrew T.
Old 2nd July 2014, 07:56 PM   #1272
Pingrs is offline Pingrs  United Kingdom
Originally Posted by AndrewT View Post
Janusz,
post1267 .doc
#1239
Old 2nd July 2014, 11:24 PM   #1273
jdg123 is offline jdg123  United States
jdg123's Avatar
kemicalx, you can assemble all you need by going to the DIYaudio store for the boards and casework then your favorite electronics site for the components from the BOM (or bill of materials). It's two-stop shopping instead of one; not bad at all!
Old 3rd July 2014, 02:00 AM   #1274
janusz is offline janusz  Australia
This is the upper part of the circuit. Values are just demonstration.
cheers,
Old 3rd July 2014, 10:25 AM   #1275
R.I.P.
The capacitor allows a different transient current limit, from the DC current limit.
A good IV protection system will allow all valid audio signals to pass into all valid audio loads.
If the IV system cannot meet that basic requirement, then it will be audible.
As a starter, look at what the limiting locus looks like when Vbe of the protection transistor is ~ 400mVbe, i.e. just turning on.
regards Andrew T.
Old 3rd July 2014, 11:13 AM   #1276
audiofan is offline audiofan  Canada
protection circuit installation you can see before and after
Old 3rd July 2014, 11:14 AM   #1277
!!!!!!!!! pictures are not in correct sequence ............
Old 14th September 2014, 08:05 AM   #1278
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Default Power board layout question
Which performs better with a center tap transformer?
1). This?
2). Or, This?
P.S.
Before I forget, I'd like to ask an additional question. Where is the most ideal location for the drainer/led section (and optional snubbers)?
A). As shown, or. . .
B). Drainer load put right after the R||D series element?
C). Drainer load put right before the R||D series element?
*As for audio quality, I might tend to guess C, because closest to bridge rectifier, but I'm not certain.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 14th September 2014, 08:35 AM   #1279
currentflow is offline currentflow  United Kingdom
Personally, I would expect 1) to be preferred in your choices. All PCB traces have resistance proportional to their length (for a given width and thickness). Option 2) has additional 0V trace length in series with the 3300uF capacitors, and consequent series resistance, which would tend to slightly reduce their peak current smoothing ability.
As for the remainder of the circuit, it resembles a 3-stage pi-filter. I suppose the circuit could be simulated by inserting small equivalent resistance values in proportion to trace CSA & lengths.
currentflow
Old 14th September 2014, 11:16 AM   #1280
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
for me, tie all caps together for the positive and negative rails, and make them meet the center tap pad in one place....
what is the purpose of the resistor and the diode?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
diyAB Amp - The "Honey Badger"Hide this!Advertise here!
diyAB Amp The "Honey Badger" build thread Variac Solid State 3058 14th June 2018 05:34 PM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 06:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
