diyAB Amp - The "Honey Badger" - Page 117 - diyAudio
Old 25th January 2014, 07:50 AM   #1161
If you want/need two dual polarity supplies that are isolated, then you need four secondaries.
Those four secondaries can come from two dual secondary transformers, or from a four secondary transformer.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 31st January 2014, 04:39 PM   #1162
So I am trying to decide whether to build a Class A 100-150W F5T or the Badger to handle difficult speaker loads(electrostatics, ribbons,etc.). Already have Aleph -40 on steroids dual mono overspeced power supply. Sounds great! for 7,8 years now. Has there been any discussion on DIY about the sound quality of the Badger? Or anyone reviewing it anywhere? Looking at Schematics it doesn't look like the simple design, minimal gain stage like the Pass series. Any help or links to info would be appreciated.
Old 31st January 2014, 05:01 PM   #1163
BobEllis's Avatar
The Honey Badger sounds very good to me. It's inspired by Self's Blameless. Sound is roughly similar to my Leach (Jens Rasmussen 5 output pair boards) with perhaps a bit more high end detail. I haven't compared it to an Aleph-J or F5T(V2C) yet, but I need to get those finished before I have surgery next month and can't lift anything for a while.
My HB uses NJW0281/0302 outputs. For difficult loads I think larger package MJL4281/4302 would be appropriate with their better thermal figures. My only concern would be SOA with very reactive loads like the electrostats. Have you measured your real output requirements? Why do you think you need 150W?
If you can post impedance/phase curves for your speakers perhaps OS will comment on suitability. He was working in a "super badger" for his subwoofer duty that may be appropriate.
Old 31st January 2014, 06:03 PM   #1164
ostripper's Avatar
For difficult loads , 2 options ...
A.) Buy expensive outputs like the semitech MG-xxxx'sComplementary Bipolar Power Transistors for High Power Audio
Double SOA ...
B.) Or use a higher gain driver like 2sc4793/2sa1837 paired with
MJL21193/4.
My badger sub is like this... with 50V rails driving a 3R /188W logitech
10" subwoofer. Not even a "hiccup" .. amp barely even gets warm.
Lower rail voltages will also allow even the little NJW's to have a much
higher SOA. 50V or below is double the SOA compared to 60+ !
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 31st January 2014, 07:24 PM   #1165
I'm basing the difficult load criteria from real world conditions. I used to run Acoustat 2+2's with a Adcom 555 first generation rated for 200W per channel. Playing rock at around 95-105 dB after awhile the fuses on the adcom would blow. Solved most fuse blowing issues with forced air cooling on Adcom heatsinks. HB is rated to 250W/channel into 4R correct? I know there is more to it than just watts. I have makings of great power supply 2kVA trannie with plenty of capacitance to go with it. Thanks for the great help guys.
Old 31st January 2014, 07:39 PM   #1166
BobEllis's Avatar
2 KVA at what voltage? Higher rails generally mean smaller SOA, so heed OS's advice to use heavier duty devices with plenty of heat sink with THICK bases. If you had trouble overheating 4 pairs of TO3's and now are looking at 3 pairs of plastic devices, yikes. Put a fan on the sinks, preferable with a temperature controller.
Rail voltage, junction temperature, current and load phase angle all play into the reliability. Using the lowest possible rails to get the voltage swing needed will help keep the magic smoke inside.
Old 31st January 2014, 09:45 PM   #1167
ostripper's Avatar
I guess then .... the MG6333/9413 would be the only "hope" for a
2R badger.
@ 50V rails , http://www.farnell.com/datasheets/866313.pdf
http://products.semelab-tt.com/pdf/A...teBipolars.pdf
...just one pair of these could almost match a WHOLE 3 pair NJW badger.
2 pair could leave the adcom in the "dust" , as well.
Spend $80 a channel with monster HS's and drive a 2R sub all day.
I saw the die of one of the MG's (almost 16 x16mm/sq).
Elector rates an amp kit with one pair at 200W !
Q-Watt Audio Power Amplifier - ELEKTOR.com | Electronics: Microcontrollers Embedded Audio Digital Analogue Test Measurement
Imagine 3 pairs .... wow !
They do cost $12usd apiece .
PS- I just want to see one built.
You would have the distinction of having the "baddest" badger !
OS
Old 31st January 2014, 10:11 PM   #1168
BobEllis's Avatar
MG6333/9413 only $9.86 at Allied Search results for "mg9413" - Allied Electronics
Old 31st January 2014, 10:32 PM   #1169
ostripper's Avatar
That is still 70+$ in OP's per badger. But I suppose that would not be
an issue for some.
OS
Old 31st January 2014, 10:46 PM   #1170
BobEllis's Avatar
Isn't a $30 per channel premium not to blow up worthwhile?
diyAB Amp The "Honey Badger" build thread Variac Solid State 2763 Today 01:57 PM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 06:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
Copyright 1999-2017 diyAudio
