diyAB Amp - The "Honey Badger"
Old 12th October 2013, 07:41 PM   #1081
rohot01 is offline rohot01  Taiwan
And I'm measure speaker output and speaker gnd.
Reading around 1XmV to 1mV. Is it normal ??
Old 19th October 2013, 04:24 PM   #1082
Krisfr is offline Krisfr  United States
Krisfr's Avatar
If one does not get you the other one will make you wish it did.
Not a good day for dead Popes or dyeing your hair either.
Never give a Systems Analyst a screwdriver or hammer
Old 19th October 2013, 05:34 PM   #1083
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Honey Badger don't give a darn..
He can take care of predators moving in on his audio turf.
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 20th October 2013, 01:28 AM   #1084
ostripper is offline ostripper  United States
ostripper's Avatar
That is normal ... as I said before R53/54 burn with no fuses ! Andrew T. suggested these and they have merit.
I do it different and just build up to the driver stage with 2 10R "sacrificial"
resistors on the rails before I go about "stuffin" outputs. Emitters of the drivers will be
+/- .6V with 2 68R's connected temporarily to the output coil.
NEVER a smoked output have I made (yoda speak ) .
To keep the Badgers "clean", consider "floating" R23
,27,32,33,36,37-41,50,53,54 slightly above the PCB or use "flameproof" devices.
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 20th October 2013, 01:37 AM   #1085
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
i make it a practice to lift all resistors off the boards by at leas 1/16 inch in all my amplifier builds, more clearance for high powered ones....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 20th October 2013, 02:16 AM   #1086
ostripper's Avatar
Originally Posted by AJT View Post
I make it a practice to lift all resistors off the boards by at leas 1/16 inch in all my amplifier builds, more clearance for high powered ones....
Best to keep "COOL". I also use 100R for R27 , this will set the VAS current source for 5+ mA (very cool).
This will not affect the compensation of the amp in any way. The Vbe resistor (R29-680R) will need to be changed to 560R to give
the same range for "Vbias" (R30).
OS
Old 28th October 2013, 08:32 PM   #1087
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
I have a lot to read into this lot of info, maybe there is going to be one Honey Badger in
Puerto Rico soon
Juan
audio fanatic only
Old 28th October 2013, 08:39 PM   #1088
still4given is offline still4given  United States
still4given's Avatar
Good for you Juan. It is a nice sounding amp and nice boards.
Old 29th October 2013, 11:15 AM   #1089
Harry3 is offline Harry3  Australia
OS I just need clarification as I am checking all the updates. In post 1036 page 104 you have the 12V zener and C6 going to earth G2.
On the original circuit diagram they go to R16. Am I missing something?
Can't wait for the new PCB's!
Old 29th October 2013, 06:06 PM   #1090
ostripper's Avatar
Yes ! The new PCB will have the C-Z jumper as default (Z goes to G2-small signal ground).
With the R , you could reference it to EITHER the "virtual" ground of the LTP (.7V - AKA "luxman way") or to the same hard ground as "Z".
Options will still be available but a "build it this way or die" is on the
screenprint (below).
Will be PMing Variac with this "final".
I just stuffed my boards (below 2), I know of NO lead space or hole issues.
Still need parts , not too economically secure. More E-waste !
OS
diyAB Amp - The "Honey Badger"Hide this!Advertise here!
diyAB Amp The "Honey Badger" build thread Variac Solid State 3058 14th June 2018 05:34 PM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 06:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
