diyAB Amp - The "Honey Badger" - Page 10 - diyAudio
Old 17th July 2011, 10:26 AM   #91
ostripper's Avatar
Default Not just simulations.
This is a working amp (X 14) ... (below is "ol' faithful") Silent/humless , no thump , LOUD as hell , very reliable.
Would not pass anything out to the forum that did not pass the "test".
Above Artwork WILL work.
OS
Amps: http://www.fidelityforce.com/ostripper
Quad core Athlon - Asus essence sound (PCM 1792A) - Slewmaster "Spooky Leach" 200W amp (final favorite).
Old 17th July 2011, 10:41 AM   #92
lineup is offline lineup  Sweden
lineup's Avatar
Ostripper
I am sure it will work well.
You put a lot of work into this project.
Remember, you were handpicked by the moderator group!
lineup
Old 17th July 2011, 10:45 AM   #93
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Originally Posted by lineup View Post
Ostripper
Nah, Don't blame the moderators! It was just me...
"The geek shall inherit the earth"
2016 S.F. Burning Amp Festival To Be Nov. 13
Burning Amp thread here on diyAudio [/B]
Old 17th July 2011, 10:52 AM   #94
lineup's Avatar
Okay, right is right, Variac.
Anyway it was a very good choice: Ostripper.
Credits.
lineup
Old 17th July 2011, 12:12 PM   #95
Banned
I think i know a decent heatsink that would suit this project, the MF30-1F-75 from conrad heatsinks, its cheap too!! Compared to other similar heatsinks from other manufs.
Old 17th July 2011, 12:44 PM   #96
5th element's Avatar
Originally Posted by ostripper View Post
Hey , 5'th
Holy poop!! ... those are the outputs !!!!
I was quite pleased when I found them too. At the time they were really cheap as well £1.70 for one and £2.50 for the other. Now they've almost doubled in price, makes me wish I'd bought a few more!
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 17th July 2011, 07:40 PM   #97
ostripper's Avatar
I still see them for 3-4 USD at mouser/digikey , I will add them to the device listing which will be integrated with the BOM.
In the finished BOM will be the Caps , resistors ,diodes , and a wide selection of semi's ..... most I have actually tried in this amp.
A full self- contained LT spice simulation "package" will be available (below- attached) It is fine tuned to show pretty accurately what we are dealing with (nothing - THD wise, below). Make sure "DIYAamp.txt" is in the same folder as "DIYA-amp-LT.asc" (models are there).
- A "Options text" - This will explain all the mods that can be done.
1. - CMC or TMC , what to omit and what to jumper - what values work.
2. - FET or BJT - How to adjust the Cascode/ current mirror to use Jfets at input.
3 - Option for lead compensation and other component changes with a explanation of the advantages/disadvantages.
4 - Advice for single sided Toner transfer construction , this board is backwards compatible for FULL DIY. I'm sure the Board Store will be reasonable, so this might just be for prototyping.
I "Branded" the PCB as requested by Mark , I want to REALLY fine tune and debug the layout for 0 errors , even down to the aesthetics of the PCB.. before I submit Gerbers (No GOLDMUND mess-ups).
An article on this amp/topology would be forthcoming (Help ... Mark , I'm no editor). Any final comments or suggestions for documentation or parts selection is welcome.
OS
Old 18th July 2011, 03:33 AM   #98
JojoD818's Avatar
MJ is to-3 (this one needs to-247/to-3p) , 21193/4 is too low Hfe for a EF2. My triple (DBT-luxman) is the beast for the to-3p/to-247 21193/4's.
LIST of outputs ....
For the full 150w
NJW0281/0302
MJL4281/4302
2SA1943/2SC5200
Sanken to-3p's (below 1) quite a selection ... any below would work.
150w (marginally)
Drivers -
MJE15030/31 or 32/33 or 34/35 - optimum ON- semi
2sa1837/2sc4793 - best for 8R use , EF2 would have the most total Hfe .
I've tried most of these devices , so I should document all these choices and include them in the book.
OS
What I have are the MJL flat packs, which I think are designated TO-264. Though I believe that I also have some in my stash the 3281/1302 and 5200/1943 pairs.
Old 18th July 2011, 02:23 PM   #99
sonidos is offline sonidos  United States
sonidos's Avatar
I also have the same flat packs (3281/1302) sitting here from a swap meet. Would be cool to use these OPS transistors in this project.
Variac and Ostripper, great idea. Very excited to try this!!
Old 18th July 2011, 06:58 PM   #100
alex mm is offline alex mm  Romania
alex mm's Avatar
Default PCB with OT in line
...... another PCB with OT in line
diyAB Amp The "Honey Badger" build thread Variac Solid State 2401 18th January 2017 10:35 AM
Honey, I smoked the Weller 8200 jackinnj Equipment & Tools 5 25th April 2011 07:07 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 04:16 PM
Copyright ©1999-2017 diyAudio
