And you were expecting normal?
#2 |
Do you work for the Transistor Marketing Board by any chance
Repairs and mods to Real Hi-Fi, guitar amps and P.A. in North East England. http://www.arklesselectronics.com |
#3 |
Looks perfect for an SMD project - but what level of noise do you sim, relative to a 1V input say?
regards |
#4 |
Yes of course, and 12R council too. Cheaper by the thousand!
All of three pennies or less at the local surplus store. Consider 4 transistor arrays such as mmpq2907 and mmpq3906. Especially where bonded device temps might be advantageous. |
#5 |
#6 |
#7 |
Nice one. I ran it through LTspice. As far as I can tell, it is all about the soft clipping. The input stage is certainly very interesting, and I'm still trying to take it all in.
#8 |
Nevermind soft clipping at +/-22V, and +/-6.5A,
nor a non-switching AB crossover. None of that stuff even slightly important. The secret entirely about rounding sharp corners off the schematic! No-one else has figured this by now? As nature abhors a vacuum, so too does LTSpice abhor a sharp corner. Place an oil slick there, and watch the electrons spin wildly out of control into the grandstands. I've added 22uF in series with R5, and 680R+68pF across R8. Defining -3dB rolloffs at 5Hz and 96KHz. Last edited by kenpeter; 11th July 2011 at 04:39 AM. |
#9 |
Intriguing circuit, especially the input stage.
But the performances do not seem to match the complexity however. The input stage has a number of symetries, and by some aspects it reminds me of cross-quads, but stacked vertically. Except there is a rather large ratio between the collector current of say Q3, Q19 and Q5, Q8 f.e.: this and the 470R coupling resistors ruin most of the Xquad effects. What is this topology supposed to achieve, Ken? (Apart from the clipping control and Iq control, which are pretty obvious.) |
#10 |
Because of 12R council you have 53MHz oscilation here.
| Page generated in 0.11658 seconds (70.59% PHP - 29.41% MySQL) with 10 queries |
