Old 8th July 2011, 10:47 PM   #1
rlaury is offline rlaury  United States
Default Depleation Mode MOSFET current sink.
Hi Group:
Can anyone point me to the proper way to calculate the resistor value to
set the current in a simple 1 depletion mode-MOSFET current sink? I know it's the voltage drop across the resistor, but do I set this to the threshold voltage or what. I've been using spice to get me in the ballpark but I would like to know the correct way.
Any help appreciated.
RonL
Old 8th July 2011, 11:07 PM   #2
jcx is offline jcx  United States
it depends on device gm, Vth which vary part-to-part so you really have to select the R once you have the mosfet in hand
tack solder a pot in place and adjust for the desired current, measure it and install the same value fixed R
Old 8th July 2011, 11:45 PM   #3
Thanks. That's what I've kinda been doing. I guess I'll have to bin the parts by Gm.
RonL
Old 9th July 2011, 02:21 PM   #4
The source current will be (Vgate-Vgs)/Rs. Of course Vgs varies from part to part and is a function of Is.
Old 9th July 2011, 02:54 PM   #5
How do we find "depletion" mode mosFETs?
I searched my datasheet file and the only depletion mode are lateral Power devices.
regards Andrew T.
Old 9th July 2011, 03:04 PM   #6
lineup is offline lineup  Sweden
lineup's Avatar
Supertex has got depletion mode MOSFETs.
And spice models for them.
Supertex: Selector Guides
For example DN2530 and DN2540
There are TO-92 and TO-220
lineup
Old 9th July 2011, 03:21 PM   #7
IXYS also has some higher V, higher current devices - we realy should start seeing these in hybrid SS + tube amp, maybe electrstatic amp designs soon
http://www.ixys.com/product_portfoli...2Easpx%3Fi%3D3
UC3846 current mode control vs. SG3525 with average current mode control mflorin Power Supplies 32 4th November 2009 04:43 PM
Depletion mode mosfet cascoded constant current source. Bas Horneman Tubes / Valves 18 10th November 2008 10:04 PM
Aleph 2 input/current source mosfet heat sink sugano Pass Labs 2 20th October 2006 01:57 AM
Need good current sink JFET or MOSFET? rlaury Tubes / Valves 7 22nd November 2005 06:14 AM
Using Ixys current regulator as current sink. G Solid State 3 16th November 2002 10:23 AM
Page generated in 0.09447 seconds (67.63% PHP - 32.37% MySQL) with 10 queries
