this is an intresting solution @ low power
need a big dissipator
visit my best audio idea http://www.esafono.it/DACTONE.htm |
#2 |
What is the purpose of including Q2, Q3 and its twin?
#3 |
increase the current to drive final device
#4 |
two resistors can make this job
#5 |
Not entirely sure how to explain this but seeing the output transistors have the collectors to the load they are effectively current sinks so when the output swings though half rail I expect there would be less chance of crossover distortion even if it were class B. As class A, so much the better.
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#6 |
Well the topic is "Do you like Class A?, and my answer is that for power amplifiers I do not
Reasons (just a few) include excess heat generation and excess cost and bulk. I believe the class of operation is but a small part in how a final design of an amp actually sounds... and that is the most important aspect.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#7 |
viceversa common collectors on output does
at the same time for accuracy it's important common emitters on input
#8 |
I tested in SPICE.
It works, with rather low distortion. Not very low. But low. THD 0.012% at 1 Watt Interesting idea, Stee. A good one
lineup Last edited by lineup; 9th July 2011 at 10:07 AM. |
#9 |
probably need a reduction of output resistors to 0.1 ohm
can you post the printscreen of SPICE values? the original schematic comes from Musical Fidelity A-1 (enhanced VAS) common emitters input schematic from LITE A-100 (common base)
#10 |
separate VAS from OS as usual
but common source input stage and again CFP with bias control (mix comes from Musical Fidelity AX-50 and Mark Levinson M9)
| Collection of Class B topologies <100mA Idle and Sound closest by Class A | tiefbassuebertr | Solid State | 36 | 30th December 2011 06:34 PM |
| Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? | tiefbassuebertr | Solid State | 18 | 14th August 2011 10:31 AM |
| Can a Class AB PP amp be said to be operating in Class A at low signal levels? | ray_moth | Tubes / Valves | 19 | 23rd January 2009 07:52 PM |
| How about a round-up of Class A kit power amps, or collectable vintage class A? | Brisso57 | Solid State | 4 | 14th February 2007 10:30 AM |
| Page generated in 0.11914 seconds (72.78% PHP - 27.22% MySQL) with 11 queries |
