Old 8th July 2011, 11:41 AM   #1
fojica is offline fojica  Romania
Send a message via Yahoo to fojica
Default Lateral mosfet driving question - Hitachi amplifiers
Hi all,
Recently I've looked through Hitachi amplifiers, their mid-to-high range from '80s, HA-xxxx and HMA-xxxx.
What I found intriguing is that in their "bigger models" they've used small capacitors in parallel gate resistances of output mosfets. The "exceptions" are HMA-6500, where there are no caps across the gate resistors and HA-8700, where on 2SJ49's in only one gate resistance with 1nF parallel cap - for both mosfets. I've checked also parts list for HA-8700, indeed only one cap is listed on "negative side", for 2SJ49.
I could not figure out the exact reason for doing this way - ok, cap across the resistor can help maybe a bit at high frequencies, but it's not worse from stability point of view ? From what I know reducing gate impedance with raising frequency would not be the best thing to do for a mosfet if you want to avoid oscillations, generally speaking.
Below are some shots from schematics described.
In case of using caps across gate resistors as Hitachi did - how to check for oscillations without a scope (mosfets temperature, zobel burning) ?
Hitachi mosfets are almost unobtainable now - I'm wondering if can we apply this "trick" with the C||R for current production Exicon/Semelab/Alfet/Renesas mosfets (single-die, not dual-die) ?
Any comments and suggestions are welcome.
Thanks,
Tibi
Old 8th July 2011, 08:37 PM   #2
I think that the gate capacitors eliminates stray inductance since the TO-3 power mosfets are not mounted on the PCB but instead wired to the PCB. They may also compensate for the different gate capacitance of the P and N mosfet.
Hope this helps.
Old 9th July 2011, 01:04 AM   #3
jez is offline jez  United Kingdom
It's because the P and N channel mosfets have vastly different source to gate capacitances.. It's to try and equal them.
Repairs and mods to Real Hi-Fi, guitar amps and P.A. in North East England. http://www.arklesselectronics.com
Old 9th July 2011, 01:46 PM   #4
thanks for answers guys
I think that elimination of stray inductance could be the main reason, because for Cgs equalization I've seen caps added on N-ch between G and S...P-ch have anyway a bigger Cgs, I see no reason to add another cap just to increase it further.
Also please note that gate resistors are different values for N-ch and P-ch...this would be the second method in quest for equal "slew rate" between N-ch and P-ch...also mentioned on Exicon app notes.
regards,
Tibi
Old 9th July 2011, 02:07 PM   #5
MiiB is offline MiiB  Denmark
does a cap in series increase capacitance..???
Old 9th July 2011, 05:23 PM   #6
@MiiB
my guess is no...we have caps in both N-ch & P-ch, usually bigger for P-ch (also bigger Cgs). but there is also an "exception", although cap value doesn't appear in the attach: for HA-7700 both caps are equal, 100pF (C726L & C727L) - indeed, for equal gate resistors
Old 9th July 2011, 07:06 PM   #7
my idea is that the 100pF cap helps secure equal drive also at higher frequencies...similar to different gate stoppers at the P and N channel.
Old 13th July 2011, 11:04 AM   #8
well...I've tried adding 33pF for N-ch and 47pF for P-ch...no accoustical change spotted so far.
recently I've seen another idea on some Albs schematic....some kind of buffer-resistor between VAS (drivers) and usual gate resistors (attached). R18 and R19 are 8.2 to 10ohm, R20-R25=100ohm. Output FETs are 2SK134/2SJ49, T3-T6 are MJE340/350.
any opinions on this ?
regards,
Tibi
Old 13th July 2011, 11:13 AM   #9
R18 & R19 are to help prevent the Zeners blowing up the driver stage with all it's carefully matched components that took many resources to work well.
regards Andrew T.
Old 13th July 2011, 11:28 AM   #10
I didn't took into account this way but it's good to have learned it
thank you, AndrewT
Renesas Hitachi 2SK1058 & 2SJ162 Lateral MOSFET billanichols Solid State 6 30th November 2011 09:18 PM
UK: Hitachi SK1058 and SJ162 Lateral Fets ShinOBIWAN Parts 2 12th April 2005 08:42 AM
hitachi lateral power mosfet in pspice JBnl Solid State 2 12th March 2005 04:49 PM
Lateral MOSFET replacements for 2SK1058 (Hitachi) jgwinner Solid State 25 11th June 2003 11:59 PM
Page generated in 0.11253 seconds (83.96% PHP - 16.04% MySQL) with 11 queries
