Location: Lawrence, a nice little college town in Kansas
Greetings,
I'm considering building the DX Blame MKII supercharged or MKIII supercharged. I already have a pair of 300VA torroids with 40V, 3.7 Amp dual secondaries which I'd like to use up. They are not center tapped. The recommended rail voltage for the Blame MKII supercharged is +/- 56V, which is perfect for my 40V secondaries. However, I also saw that the power supply which Carlos recommends for the Blame series, requires a center-tapped transformer and 2 diodes for rectification. I'm making the assumption that 56 volts is 56 volts, and that I can use whatever supply I want, provided it supplies the correct voltage, and has enough current (300VA/channel should be plenty). But you know what they say about assumptions! I'd just like some confirmation that I'm right before I commit to the DX Blame MKII / MKIII and purchase a different PS board. Thanks in advance! -Byron |
#2 |
Put one bridge rectifier on each transformer and wire + on one to - of the other and bingo, centertap.
300VA is a bit low but 50-75 watts per channel should be plenty anyways.
The point of life is to build atleast one audio amplifier before you die. |
#3 |
Hi Tekko,
Thanks for the reply, but I think what you are talking about is different from a power supply using a center-taped transformer. This Wikipedia entry: Center tap - Wikipedia, the free encyclopedia shows the kind of power supply designed by Carlos for the blame series which can be seen here: http://www.nabucoeletronica.com.br/d...-schematic.pdf. I can not convert a non-center tapped transformer to a center tapped one post-rectification. |
#4 |
I have done this with two separate transformers and it works just fine.
Put the two transformers in series and you get a centertap, or do the same thing after rectification and you get a centertap. Its essentially the same thing as when a transformer has two separate secondaries, you use two FW bridges.
#5 |
A dual secondary transformer can be wired with the two secondaries in series. This is equivalent to a centre tapped transformer.
I use a 230:40Vac transformer and when powering two channels each biased to 210mA, I have +-58.5Vdc when mains is at it's usual 244Vac.
regards Andrew T. |
#6 |
OH! Now I get it!
![]() Thanks guys. |
| Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release! | destroyer X | Solid State | 500 | 2nd May 2012 10:15 AM |
| DX BLame ES, ST, MKII, MKII Supercharged Groub Buy Interest | Mitchel | Group Buys | 156 | 22nd February 2012 07:46 PM |
| FS: DX Blame MKII amplifier set + power supply + heatsinks | supernet | Swap Meet | 5 | 29th November 2010 10:33 PM |
| Dx Blame MKII and Dx Blame MKII Supercharged released NOW! | destroyer X | Solid State | 1 | 29th October 2010 01:00 PM |
| Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST | destroyer X | Solid State | 4 | 25th September 2010 06:41 PM |
| Page generated in 0.08586 seconds (74.84% PHP - 25.16% MySQL) with 10 queries |
