Old 7th July 2011, 06:06 PM   #1
Alaza is offline Alaza  Denmark
Default Circuit schematic question for Rotel amp.
Hi guys,
I have a Rotel RA-840BX4, and after the Tone switch started being less and less stable I decided to dismount it and short the two channels, forcing it off. My question however is the application of the IC701 in the circuit. The manual is here:
http://www.acousticpsychos.com/Files...BX4-int-sm.pdf
As far as I can see it just gives a gain of approximately 3, but why is it necessary?
Thank you
Old 7th July 2011, 11:46 PM   #2
jaycee is offline jaycee  United Kingdom
Just buffering for the passive tone control stage id say. Combined with IC702 it makes a gain of +6 which is pretty usual for a preamp. I'd bypass it and adjust the feedback network of IC702 to make the +6 gain (or less if you dont need so much)
Old 7th July 2011, 11:54 PM   #3
Weird feedback loop, i bet the amp would sound alot better if the feedback was routed to the other LTP input like usually done, than beeing inverted through a opamp and then sent to the signal in together with the input signal.
The point of life is to build atleast one audio amplifier before you die.
Old 8th July 2011, 05:22 AM   #4
Since I have forced the Tone switch off, I will never be able to use the Treble and Bass functions again. So couldn't I in practice also just rewire it so I'd bypass IC701 and IC702, or is 702 needed for something I can't see?
Old 8th July 2011, 10:05 PM   #5
I asked a colleague of mine in terms of removing the IC701, and he said it would mess up the system since it's acting as an impedance matcher and buffer, so you would have a voltage division between R711 and R601, which is not desirable.
Service Manual/ schematic for Rotel ROTEL RHCD-10 Michi CD player Staykov Digital Source 5 16th May 2012 12:24 AM
Rotel 855 PICS, dac & opamp question for newbie... psonic Digital Line Level 71 8th April 2010 11:59 PM
schematic for Rotel RC-850 pre-amp? kmj Solid State 2 9th January 2007 09:53 PM
rotel rb981 power amp schematic homertooties Solid State 1 25th November 2005 07:30 AM
Page generated in 0.08622 seconds (71.53% PHP - 28.47% MySQL) with 10 queries
