Hallo Everybody,
I am trying to repair my Superscope quad amp. Two of the output transistors need to be replaced. These are B512 type. I have not been able to find these with the local suppliers here and shall be glad if somebody can advise on suitable substitutes. Regards |
#2 |
Is is 2SB512 ? View 2SB512_4457715.PDF datasheet online --- IC-ON-LINE
http://cgi.ebay.com/new-rare-2SB512-...2#ht_500wt_922
The point of life is to build atleast one audio amplifier before you die. |
#3 |
If they are TO-220 packaged 2SB512, then there's a whole lot of modern devices that would work - TIP41C would probably be adequate.
#4 |
Thanks for the info.
They are TO-220 packaged devices. The amp is a SuperScope QA450. I found that the Marantz 2215B receiver has a very similar circuit and PCB layout with some variations. Anybody here has a copy of the service manual for the QA450? Regards, |
#5 |
Should be TIP42C - 2sb512 is PNP. And they would work fine.
Steve |
| RS232 - Does it require a termination? | poynton | Everything Else | 5 | 21st March 2011 06:52 AM |
| I require a DAC | HimeshP | Digital Line Level | 6 | 30th December 2010 11:54 AM |
| Do I really require this box volume? | rhythmdiy | Multi-Way | 6 | 4th November 2008 04:25 AM |
| Would this require degaussing? | ewan | Everything Else | 4 | 5th December 2003 10:59 AM |
| Page generated in 0.06826 seconds (83.54% PHP - 16.46% MySQL) with 10 queries |
